Fibre broadband..... Flashing green dsl light.
- Fibre broadband..... Flashing green dsl light.
01-06-2013 2:27 PM
I've upgraded to plusnet fibre now since last month, so I assumed everything would be ok, till wk before last when the green dsl was flashing it came back on the next day. So I woke up yesterday morning to find the dsl light flashing yet again...as of yet has still not come on!
Any suggestion? Thinking it may be a fault with my line.
Regards
Re: Fibre broadband..... Flashing green dsl light.
01-06-2013 10:26 PM
Try opening a faults ticket and Plusnet will run a test etc.. And if there is something wrong, a engineers visit maybe required.
Jamie
02-06-2013 12:27 AM
02-06-2013 8:34 AM
02-06-2013 9:13 AM
My phone line seems to be completely off... Think that's down to plusnet running test.
My area code is bs23.
02-06-2013 9:25 AM
There don't seem to be any widespread reported problems in W-S-M (01934) so it probably is your own line
02-06-2013 9:35 AM
let's see how prompt openreach are at fixing my fault.
02-06-2013 9:43 AM
02-06-2013 10:01 AM
02-06-2013 10:27 AM
02-06-2013 10:45 AM
I will be over the moon when it's finally resolved
02-06-2013 2:24 PM
I'm sorry to hear that you're having problems with your connection.
If you've raised a support ticket with us at http://faults.plus.net we would be more than happy to take a look into things for you.
02-06-2013 2:32 PM
03-06-2013 4:36 PM
I can see your line has been tested and our faults team will be in-touch with the outcome.
03-06-2013 6:37 PM
