Fibre and using non PN routers/BT modems
- Fibre and using non PN routers/BT modems
01-06-2011 2:33 PM
My question is, can anyone suggest a single router/modem to replace the BT modem and Netgear WNR1000 that are supplied? I hate the separate boxes for one thing and don't have room to accommodate both machines along with my NAS drive in the necessary location. Secondly, and more importantly, the range on the wifi on the Netgear is worse than my old Netgear DG834GT.
Thanks.
Re: Fibre and using non PN routers/BT modems
01-06-2011 2:39 PM
01-06-2011 2:49 PM
1 " for one thing and don't have room to accommodate both machines along with my NAS drive in the necessary location." - You don't need to put them all in once place, far from it. The Modem can go anywhere up to 30m from the main socket. The Router can go a further 30m from that too!, and your NAS, well, heck with use of switches that could be on the other side of the planet if you wanted.
To give you some idea. My master socket is in the corner of the house in an upstairs bedroom. I chose to have the modem above that. Then a 30m CAT5 cable runs into my study, where the router is located. My other kit is there too, but it doesn't need to be.
01-06-2011 2:57 PM
02-06-2011 11:23 AM
With the fibre product you must use the supplied modem.
Jojo
02-06-2011 1:20 PM
02-06-2011 2:42 PM
or...
BT won't sell other ISPs a self-install FTTC package yet, probably because they think they will get a lot of support problems as a result. Plusnet want you to keep BT onside.
I can never remember which is correct.
02-06-2011 3:46 PM
If it works out of the box.... great, but if you ever have -any- problem PN and BT won't go near it with a barge pole.
A bit like adding a turbo to your car, and then trying to claim the work on the manufacturer warranty when it goes boom.... no chance.
As such PN can't "condone" the use of the other modems, though they probably can't tell if you use your own.
So all depends how tech savvy/brave/gutsy you feel. But the official line for a while will always be "you must use the supplied modem". Flout that at your own risk.
02-06-2011 3:52 PM
02-06-2011 4:11 PM
Basically, with fibre, BT have set the demarcation point as the modem rather than the master socket. And considering this is provided as part of the service as well as the fact they will replace any faulty ones throughout the length of service and faults will also be easier to fix and identify if any problems arise.
Jojo
02-06-2011 4:13 PM
I agree and think this has mainly limited options at the moment due to competition/supply reasons as well as the support issues. Call me fussy, but I just like to be tidy and hate having two boxes when one should be able to do the trick. I will persist with the mess for the time being, provided my son doesn't complain too much about his bedroom being an expanding data-centre; though long term it will all go in the loft.
Oh, and thanks Jojo for the formal response; despite the X-Files inspired response it has provoked earlier.
