Fibre Usage Limit?
- Re: Fibre Usage Limit?
Fibre Usage Limit?
16-07-2014 12:22 PM
Hello,
I was wondering if there is a Fibre Usage Limit as my Fibre usage has been fairly high, probably a bit too high. Just wondering if Im likely to be put on the 'bad boys pipe' like what happened to 240 users back in 2004.
Cheers
Cheers
Message 1 of 6
(819 Views)
5 REPLIES 5
16-07-2014 12:27 PM
no there isn't and no you won't be
Message 2 of 6
(537 Views)
16-07-2014 12:32 PM
I hit 600gb so was a little concerned
Message 3 of 6
(537 Views)
16-07-2014 12:34 PM
that all?
Message 4 of 6
(537 Views)
16-07-2014 12:45 PM
thats ok then?
Message 5 of 6
(537 Views)
16-07-2014 1:42 PM
No problems, it is fully unlimited.
I regularly use 500Gb+
Message 6 of 6
(537 Views)
