Fibre Speed Tests
- Fibre Speed Tests
Re: Fibre Speed Tests
19-03-2014 11:55 PM
20-03-2014 7:26 AM
20-03-2014 9:21 AM
There may have been a brief drop over night due to planned maintenance (PW236449).
20-03-2014 2:01 PM
Our tests have found a fault with your broadband service.
BOT Logged faults or not?
I am starting to get confused on whats happening.... and will someone tell me what and where the fault is if there is one?.
#82944630 support ticket number
Although a speed test doesn't look good at the moment
jim:csa
20-03-2014 2:04 PM
Unfortunately it looks like the remote work hasn't resolved the issue, which is why an engineers visit is required. The engineer will be in a better position to be able locate any physical issues whilst carrying out any necessary remote work too whilst on site.
20-03-2014 2:18 PM
Apologies Jim (Oldjim) for including names of support staff I didn't realise.
20-03-2014 2:51 PM
update..... the BT line bloke tested the phone line only and thats all ok but did say he couldn't rule out fibre or equipment at the exchange!
21-03-2014 9:56 AM
So was I the first in my area to opt for fibre?
21-03-2014 10:02 AM
25-03-2014 1:55 PM
Friday: OpenReach Engineer replaced the BT ECI modem for the Slightly smaller BT Huawei one. She claimed the Huawei should have been the one installed originally but wasn't. Apparently, the line speed based on distance for copper wire to cabinet and fibre to exchange I should be getting a max of 47mb on the 80/20.
Which confused her based on the current profile at the time was set to 40.
She as cleared the line of any faults and reset the DLM so the next 10 days is now a waiting game.
The Througput speed still seems to be quite random and slow.
General use: the IP to server seems to be stable and consistent
However, still getting seriously slow speeds and on some occasions where I am streaming media it some time buffers. I assume its the DLM working its business.
24/3/14 D6.62/U2.06 mbps 221ms @7.04pm
24/3/14 D24.27/U8.58 mbps 67ms @10.41pm
25/3/14 D2.94/U2.97 mbps 279ms @7.04am
BT Wholesale Test @1.26pm remotely
Do Plusnet do a 40/10 unlimited profile package?
25-03-2014 3:14 PM
Yes we can provide Unlimited on 40/10 or 80/20 depending on the individual line estimate. I can move you onto 40/10 if you'd like?
25-03-2014 10:49 PM
26-03-2014 11:31 AM
Hopefully it's a one-off but ideally we'd like to know what caused it!
02-04-2014 11:28 PM
The fastest I have seen is 40.45/8.86 27/3/14 18:21
so why do I still see speeds at the same rate of the fastest ADSL2 line? its not really breaking the speed barrier when it comes fast internet or is this one big promotional hype?
Date Down TBB Down HTTPx6 Upstream
Wed 02/04/14 22:56 25.10 Mbps 25.07 Mbps 8.60 Mbps
Sun 30/03/14 00:01 23.23 Mbps 22.59 Mbps 8.64 Mbps
Thu 27/03/14 22:00 22.16 Mbps 24.46 Mbps 8.66 Mbps
Wed 26/03/14 21:12 24.50 Mbps 24.60 Mbps 7.87 Mbps
Tue 25/03/14 22:46 17.49 Mbps 24.55 Mbps 8.70 Mbps
Sat 22/03/14 23:07 17.85 Mbps 21.67 Mbps 8.35 Mbps
since engineers visit see above
Thu 20/03/14 22:58 22.68 Mbps 24.81 Mbps 9.94 Mbps
Wed 19/03/14 22:43 39.09 Mbps 38.74 Mbps 9.85 Mbps
Wed 19/03/14 21:14 25.39 Mbps 24.17 Mbps 3.97 Mbps
Tue 18/03/14 23:09 38.29 Mbps 38.95 Mbps 9.70 Mbps
Tue 18/03/14 21:42 38.32 Mbps 38.89 Mbps 9.81 Mbps
Mon 17/03/14 23:08 38.56 Mbps 38.69 Mbps 10.02 Mbps
Mon 17/03/14 22:50 38.69 Mbps 38.71 Mbps 10.02 Mbps
Mon 17/03/14 22:31 38.54 Mbps 38.90 Mbps 9.95 Mbps
Mon 17/03/14 22:30 37.89 Mbps 38.73 Mbps 9.88 Mbps
Mon 17/03/14 22:07 21.90 Mbps 24.52 Mbps 9.94 Mbps
Mon 17/03/14 21:05 17.70 Mbps 19.51 Mbps 6.91 Mbps
Mon 17/03/14 20:02 16.61 Mbps 22.42 Mbps 9.71 Mbps
03-04-2014 9:22 AM
Are you running any other programs whilst running these speed tests?
