Fibre Speed Profile
- Fibre Speed Profile
Fibre Speed Profile
20-05-2013 4:07 PM
Just had fibre installed PlusNet Fibre Unlimited and had an issue where I was only getting 8.5 Mbit download. Spoke to PlusNet support and they reset my profile to 37 Mbit, however I believe my profile should be the 80/20 profile.
Can anyone from PlusNet check my profile settings to see if it should be set to the 80/20 profile even though I can't get full speed?
Regards
Re: Fibre Speed Profile
20-05-2013 8:47 PM
If the BT IP profile from the result is higher than 37Mbps then you should be on the 80/20 product. If you aren't, you can ring in again, but someone from the DCT will have to look at your post here tomorrow would be best.
20-05-2013 9:11 PM
I have run this and my profile appears to be set to 40/10 rather than 80/20 so I would be grateful if a PlusNet rep would get this changed on my account.
dick:quote
20-05-2013 10:56 PM
21-05-2013 7:33 AM
Regards
21-05-2013 7:43 AM
21-05-2013 7:47 AM
21-05-2013 10:58 AM
I'd guess in this case we provisioned on 40/10 due to the line speed estimate for FTTC which is currently showing up to 24.6 down and up to 5.7 up. As it's performing significantly better than that though it's probably worth a go at 80/20 - I'll place the order for you now, hope it gets an improvement
21-05-2013 12:22 PM
Whats the turnaround on this?
I was surprised at the speed as cabinet is not that close although when I had adsl it was estimated at 5.5 Mbit but was syncing around 10Mbit.
Regards
21-05-2013 2:51 PM
21-05-2013 3:11 PM
22-05-2013 10:59 AM
22-05-2013 3:39 PM
Do I need to power cycle the modem?
22-05-2013 3:52 PM
Just log into the router and disconnect the PPP session and reconnect the session again.
Rebooting the modem is a no no as dlm can see that as an issue and intervene and not in a good way
22-05-2013 6:28 PM
Attached is the speedtest result, can you check your end that my PlusNet profile is OK as I am getting nearenough exactly the same speeds? I appreciate that I was already getting more than predicted but every bit is a bonus.
