Fibre Router
- Fibre Router
Fibre Router
27-02-2013 12:24 PM
Hi, Just ordered fibre broadband and ordered the "fibre router" (Technicolor TG582n Fibre Router). Is this the device BT connect to the master socket or is it just a router?
If it's just a router then I already have one of those so Plusnet please can you cancel my order (Order number : HW25941389) as I do not require this. I would call but the telephone queue is currently at 15 mins.
Thanks, Simon
Thanks, Simon
Message 1 of 7
(1,457 Views)
6 REPLIES 6
Re: Fibre Router
27-02-2013 1:00 PM
Hi
BT install a fibre modem, and you then need a router (such as the TG582n router) to connect to the BT modem. This router needs to have an WAN RJ45 port.
Message 2 of 7
(723 Views)
Re: Fibre Router
27-02-2013 1:10 PM
There's a diagram here in the installation guide.
http://www.plus.net/support/broadband/hardware/technicolor-582n-fibre-setup-guide.shtml
Message 3 of 7
(723 Views)
Re: Fibre Router
27-02-2013 1:13 PM
I have a Billion BIPAC 7800N which has an "EWAN: RJ-45 Ethernet port for connecting to ADSL / Cable / FTTH / VDSL device" as well as an ADSL port so I assume this will be OK.
PLUSNET - Please cancel the router order on the original post.
Thanks!
Thanks!
Message 4 of 7
(723 Views)
Re: Fibre Router
27-02-2013 1:23 PM
I would open a ticket to increase the chances of them seeing your request in time
Message 5 of 7
(723 Views)
Re: Fibre Router
27-02-2013 1:39 PM
Thanks, good point, have done so.
Message 6 of 7
(723 Views)
Re: Fibre Router
27-02-2013 2:20 PM
Hi there, that's been cancelled for you and I've also updated your ticket
Chris
Chris
Message 7 of 7
(723 Views)
