Fibre Broadband less than half advertised speed
- Re: Fibre Broadband less than half advertised spee...
- « Previous
- 1
- 2
- Next »
Re: Fibre Broadband less than half advertised speed
15-09-2014 12:32 PM
Hi parisbeach,
I've ran some tests on the line and its not picking up on any issues. So if you can hear noise on the line we will have to arrange for an engineer visit.
If you can PM me your availability this week I'll book something in for you.
Thanks,
Dan
Thanks,
Dan
Message 16 of 22
(569 Views)
15-09-2014 12:34 PM
Quote from: parisbeach Yes i have sounds like a humming sound with the occasional pop
did you test it with a corded phone? (and not a cordless phone), just in case the noise is coming from the cordless phone itself.
Message 17 of 22
(569 Views)
15-09-2014 12:38 PM
HI just re ran it again as had son crying last time nothing this time all quiet this time i will run another test in ten mins and see if it happens again
Message 18 of 22
(569 Views)
15-09-2014 1:23 PM
HI fourth test is a no . noise on the line has gone dont know if it was the phone or what but that seems to have stopped. stillbad result
http://www.speedtest.net/result/3761394643.png
Message 19 of 22
(569 Views)
15-09-2014 2:12 PM
can you use this instead - http://speedtest.btwholesale.com/
and then do the further diagnostics afterwards.
make sure NOTHING else is doing anything on the internet when you run it.
Message 20 of 22
(569 Views)
16-09-2014 12:32 PM
Hi when i go to do the further diagnostics the page crashes is really annoying me
Message 21 of 22
(569 Views)
16-09-2014 12:41 PM
Hi just ran a speed test dont know whats happened but am back to full speed what the hell check it out rather pleased
http://www.speedtest.net/result/3763799834.png
Message 22 of 22
(569 Views)
- « Previous
- 1
- 2
- Next »
