Fibre Broadband and Wireless Adapters
- Fibre Broadband and Wireless Adapters
24-01-2012 9:00 AM
I have a few questions initially. The N150 supports Wireless-N and Wireless-G. If I wanted to purchase a new USB wireless adapter around the £20 mark what type would be recommended to try and improve my speed.
I have seen a Wiress-N 150mbps 802.11n high gain OR one which says 802.11n 300mbps (which is cheaper) or can Plusnet recommend one?
Also on the Netgear site is says the N150 is an ADSL Router (modem + router combined).. Why is it that with fibre it can't be used this way and you need the separate modem?
I have no extension kit. I ordered one at the time but given the location of my modem/router, one wasn't used.
Any advice, specific or general around this area and how I can make it better would be good.
Is it to be expected that WIFI speeds would be less than wired?
Thanks for any replies I may get.
Nick
Re: Fibre Broadband and Wireless Adapters
24-01-2012 9:13 AM
Wireless will almost always be less than wired the headline speed that you see (e.g. 300mbps) needs to be halved and over heads taken off so at best under totally ideal conditions you'd expect to get max of 75mbps.
However there are very few cases where you can expect ideal, move the pc more than about 8 feet away and you lose signal strenght and therefore throughput, interference from other electrical appliances and your speed will drop off noticeably.
To get the best wireless signal you'd need a 5GHz banded router and adapter as this is less prone to interferance and also less common - but is more expensive and you'd need new adapters for all your kit.
If your pc is static, i.e. not a laptop it might be worth looking into powerline adapters to get an improved speed, getting a better wireless signal would be difficult.
As to why you can't get a fibre modem and router all in one i'm not sure, but all suppliers are like this both in this country and abroad.
24-01-2012 9:28 AM
Question. If it's ok to use extension cabling from the master socket (up to 30m ?) then why is it not also ok to use secondary telephone sockets to plug the modem into? That would have been my ideal solution as the previous modem was plugged into a secondary socket which meant it was closer to the desktop but now I am told the fibre modem has to be plugged into the master socket. Is this crucial for it to work properly?
Thanks again
Nick
24-01-2012 9:36 AM
24-01-2012 9:40 AM
24-01-2012 9:57 AM
24-01-2012 10:01 AM
24-01-2012 11:32 AM
http://is.gd/VEGyaQ
24-01-2012 12:01 PM
24-01-2012 6:07 PM
My desktop is a fair distance away from the router and the onboard wireless card was hopeless. It couldn't keep a stable connection to save its life. I bought a TP-Link TL-WN822N 300MBPS High Gain Wireless N USB Adapter and it has proved to be a godsend and enabled me to get back to online gaming. I can see the wifi signals from half the street (!) and I get good speeds too.
Worth a look on reputable sites and should retail between around £10-15.
24-01-2012 9:46 PM
I don't know for sure that the N150 is an ADSL modem/router. But even if it is, FTTC uses a different modem standard (VDSL), which ADSL modems cannot handle. For that reason, you generally need a separate VDSL modem (the BT box). VDSL modem/routers do exist but are a) expensive b) not really 'allowed' as BT are responsible for up to and including the VDSL modem.
VDSL squeezes a lot more out of the wires it runs over (from the cabinet to the modem). In order to be reliable, it needs as few connections as possible, which is why it isn't 'possible' to connect the VDSL modem to anything except the master socket. However, there are things you can do... such as a) use a longer phone/modem cable between the master socket and the VDSL modem (use a good quality one) - which is all that a data extension kit is b) use a longer ethernet cable between the VDSL modem and the router c) both!
The router that plusnet supply is just a cheap router and as such it does not have the ultimate in wireless performance - though it will be quite sufficient for many situations, and it might well be fine for yours, if it is the case that your wireless adapter is the weak link. For a desktop, assuming wired is out of the question, I would be looking either for a PCI card wireless adapter that has at least one and preferably three external aerials, or a USB adapter that can be repositioned so that you can experiment to see where the best reception is. Whichever you go for, you can't benefit from a 300Mbps adapter with your current router, or from a 5GHz adapter either - both will work, neither will do any harm and they may be no more expensive. Don't rule out the powerline adapters either.
25-01-2012 1:28 PM
My main problem with my set-up is the inconvenient place the builders of the house put the master socket (IMO). It's basically in the Living room but almost behind the door therefore cabling (phone cable or lan cable) to a different/better location would mean going via the front door which is tricky/messy but not something I've dismissed completely. I could at least test it out prior to drilling holes etc.
I have currently got a USB wireless adapter plugged (via a cable) into the PC (USB 2.0) and that is marginally better than the PCI card but still not great. I like the idea of the high gain USB adapter. If it really does get a much better reception that sounds worth a shot otherwise I am sticking wires over my front door!
Thanks again all
Nick.
