Fibre Broadband Speed Low
- Re: Fibre Broadband Speed Low
24-03-2014 7:02 PM
Had Fibre installed this morning (second attempt) but the download speed is only at about 6mb. Upload speed is 15mb. I know that it takes a while for the speed to settle but surely I should be getting more than this. I'm not expecting to achieve 76mb but I do expect a lot more than 6mb.
Can someone confirm if this is normal for newly installed fibre and that the speeds will increase significantly in the vert near future. Or do I have a problem?
Just checked my high speed broadband info in connection settings and it records that my current line speed is 7.15 Mb but my estimated speed is 75mb. I should be on the 76mb unlimited package so I'm assuming that my settings are not correct.
Message 1 of 5
(1,040 Views)
4 REPLIES 4
25-03-2014 1:20 PM
Hi cheetla,
I've just made some changes to your Speed Profile set on our system. Can you restart your Technicolor Router and see if that's improved things for you?
Message 2 of 5
(543 Views)
26-03-2014 6:04 PM
Thanks Chris,
Line speed is now 78mb and all seems ok.
I keep checking the download speed on P/N speed checker but it still comes out at about 7 - 8mb. I then used the BTW performance test and download speed shows 65mb.
Is this a problem?
Web browsing doesn't seem any faster than when the download speed was 6mb.
Many thanks
Is this a problem?
Many thanks
Message 3 of 5
(543 Views)
27-03-2014 2:33 PM
You probably won't notice much of a difference in speeds whilst web browsing to be honest, it's more downloading and streaming that you'll really notice a difference.
The speed test that we have on our website isn't working correctly at the moment - there should be a note on it to advise of this.
Message 4 of 5
(543 Views)
27-03-2014 10:39 PM
Thanks for the help.
Downloads speeds are now superfast - updated Itunes earlier and it completed in seconds rather than the usual 2 minutes. So all seems well.
Cheers
Cheers
Message 5 of 5
(543 Views)
