Fiber optic peaks
rocky4x4
Fiber optic peaks
I have noted a very sudden fluctuation in download speed which appears to have started yesterday .Upload speed is unaffected. I ran several speed tests today and the results are below. A couple of the speed tests had to be abandoned as the download test actually stopped. I have reset the router a couple of times but not noted any difference. One speed test is as normal typically 25000kbps, the next even a  minute later slows considerably for example 7706kbps. I had FTTH installed in January and as the historic speed tests show  (after an initial speed fault )  until today the download and upload speeds have been reasonably consistant and stable.I am not aware of any service issues so any assistance would be appreciated.
Today 19:31 31626 kbps (3.95MB/s) 1823 kbps (228kB/s) Share  Smiley
Today 18:4010803 kbps (1.35MB/s) 1820 kbps (228kB/s) Share  Sad
Today 18:34 25312 kbps (3.16MB/s) 1820 kbps (228kB/s) Share  Smiley
Today 18:34 26123 kbps (3.27MB/s) 1820 kbps (228kB/s) Share  Smiley
Today 18:33 28058 kbps (3.51MB/s) 1821 kbps (228kB/s) Share  Smiley
Today 18:33 8324 kbps (1.04MB/s) 1819 kbps (227kB/s) Share  Sad
Today 18:33 7706 kbps (963kB/s) 1811 kbps (226kB/s) Share  Sad
Today 18:31 15910 kbps (1.99MB/s) 1825 kbps (228kB/s) Share  Sad
Today 18:31 5592 kbps (699kB/s) 1682 kbps (210kB/s) Share  Sad
Today 17:54 24959 kbps (3.12MB/s) 1818 kbps (227kB/s) Share
Today 17:53 14329 kbps (1.79MB/s) 1816 kbps (227kB/s) Share
Today 17:53 13600 kbps (1.7MB/s) 1810 kbps (226kB/s) Share
Today 08:56 26233 kbps (3.28MB/s) 1816 kbps (227kB/s) Share
Today 08:56 7489 kbps (936kB/s) 1694 kbps (212kB/s) Share  Sad
Saturday 19:06 25614 kbps (3.2MB/s) 1801 kbps (225kB/s) Share
Feb 4, 18:19 24570 kbps (3.07MB/s) 1813 kbps (227kB/s) Share
Jan 29, 20:50 23056 kbps (2.88MB/s) 1813 kbps (227kB/s) Share
Jan 28, 18:23 23375 kbps (2.92MB/s) 1820 kbps (228kB/s) Share
Jan 26, 21:01 25044 kbps (3.13MB/s) 1822 kbps (228kB/s) Share
Jan 26, 21:01 15357 kbps (1.92MB/s) 1820 kbps (228kB/s) Share
Jan 26, 21:00 24518 kbps (3.06MB/s) 1818 kbps (227kB/s) Share
Jan 25, 20:57 22632 kbps (2.83MB/s) 1822 kbps (228kB/s) Share
Jan 25, 20:57 22958 kbps (2.87MB/s) 1813 kbps (227kB/s) Share
Jan 24, 20:04 19417 kbps (2.43MB/s) 1812 kbps (227kB/s) Share
Jan 22, 19:42 22139 kbps (2.77MB/s) 1819 kbps (227kB/s) Share
Jan 22, 19:40 23448 kbps (2.93MB/s) 1807 kbps (226kB/s) Share
Jan 22, 17:15 17578 kbps (2.2MB/s) 1816 kbps (227kB/s) Share
Jan 22, 17:14 18767 kbps (2.35MB/s) 1817 kbps (227kB/s) Share
Jan 21, 17:23 26341 kbps (3.29MB/s) 1813 kbps (227kB/s) Share
Jan 21, 17:23 28055 kbps (3.51MB/s) 1821 kbps (228kB/s)
6 REPLIES 6
javixeneize
Fiber optic peaks
Hi
During last days, im having a lot of peaks on my speed. Doing speedtest, it starts at 30 mbps, then falls to 4mbs, back to 25mbs, etc...
And... average speed is about 8mbps
Have any of you experienced this?
jojopillo
Re: Sudden fluctuation in fibre download speed
HI rocky4x4,
It's not easy to put your finger on fluctuations like that. If you see it happen again the it might be worth setting up a PPPoE dialler and running a speed test directly from the modem. If you're not sure how to do that we have a couple of articles on our Community Library that will show you how.
Jojo Smiley
jojopillo
Re: Fiber optic peaks
HI javixeneize,
What time does it happen, how often does it happen, is it a wired or wireless connection to the router?
Jojo Smiley
javixeneize
Hi
It happens all the time through a wireless connection
It was working fine, but, two days ago, somebody from Kelly's came to my house to replace the modem. Im experiencing this since that moment, but im not sure if this is related
In the same hand, the router displays a yellow light instead a green one, it means that sync has been done at 10mps instead of 100mps
jojopillo
As it's wireless, I would certainly try it wired next time it happen, as it just may be interference on the wireless channel. Smiley
Fixes: 62
Topics merged and duplicate post removed
