Fed up of this appalling yoyo broadband!
- Re: Fed up of this appalling yoyo broadband!
02-03-2013 3:31 PM
Quote from: JamieDanjoux Log into your router and click disconnect, Count upto 30secs then hit connect, this should hopefully sort it out!! Because you have to change gateway. Make sure it doesn't begin with PCL and starts with PTW or something else. Check here at http://usertools.plus.net
I did this last nite and speed came back straight away, from 2mb back to 45mb, checked the gateway before and have moved to a different gateway now. It only took 2 minutes, i only restarted my own router not the openreach one.
Plusnet know about the problem and are working on it.
02-03-2013 4:20 PM
I have jumped gateways AGAIN but STILL the same problem! I AM SO SICK OF THIS RUBBISH.
you know i am so lucky my next door neighbour lets me use his network, cause theirs (sky) never does buffering on a 2 signal wireless connection.
02-03-2013 5:17 PM
02-03-2013 5:22 PM
02-03-2013 5:56 PM
02-03-2013 7:11 PM
Jamie
02-03-2013 7:24 PM
What you needed was:
url= ..... ]here[/url instead of url]http://here= ..... [/url
02-03-2013 7:45 PM
02-03-2013 7:50 PM
Best Regs
Jamie
02-03-2013 8:31 PM
OK.
02-03-2013 8:36 PM
02-03-2013 8:46 PM
Hope it works!!
02-03-2013 8:47 PM
03-03-2013 10:10 AM
03-03-2013 10:14 AM
