Fed up of slow broafband- why am I paying for this?
skimanant
Joined plusnet May last year. Was very pleased to start, in an ADSL2 area, .7 miles from exchange, was getting 11mbps and a ping of 24ms. Great for Warcraft!
Howvere, since December I am now getting constant issues. Im fed up of emailing and phoning in to be told have you changed the filter etc. I'm getting just over 2 mbps- not bad compared to some areasm but pants for living in a city on ADSL2. My ping goes up to 128ms sometimes. Warcraft is pants. On contacting BT, they say they can supply me at "at least" 8mbps. Plusnets own tools say I should get aroiund 9mbps.
Im on plusnet extra- what do I get for it? I dont use my allowance because I cant download fast enough. Its a rant, sorry, but Ive been going on now since December. I email and ask for a complimentary month which is ignored. Do I wait till the end of the contract and migrate or take the ISPA route?
6 REPLIES 6
Oldjim
Resting Legend
Fixes: 63
Re: Fed up of slow broafband- why am I paying for this?
Have you raised a fault
What are the router stats - noise margin, attenuation and speeds
What does the BT speedtester give
What does this say for Current Line Speed https://portal.plus.net/my.html?action=data_transfer_speed
Are you connecting by wireless
orbrey
Hi skimanant,
Looks like the dropping connection has caused your line profile to be reduced. I've asked one of our faults guys up here to take a look for you and get it moved on, there should be an update on there shortly.
skimanant
Quote from: skimanant
My latest stats:
Download speedachieved during the test was - 2032 Kbps
For your connection, the acceptable range of speedsis 800-2000 Kbps.
Additional Information:
Your DSL Connection Rate :2747 Kbps(DOWN-STREAM), 440 Kbps(UP-STREAM)
IP Profile for your line is - 2000 Kbps
and from a while ago:
TAP ID: TAP-1 TAP-1
Start Date/Time: 12-12-2010 22:24:37 12-12-2010 22:23:52
Test Duration: PT30S PT1M9S
Domain Name:
VPI: 0 0
VCI: 0 0
Infrastructure Type (C+ C++ HG/LTS): LONS LONS
System Name: EUSC Performance Tester EUSC Performance Tester
System Host: EUSC Performance Tester EUSC Performance Tester
Policy Type: BestEffort BestEffort
Policy ID: WBC WBC
Profile Rate: 443 6500
Test File Size: 1326187 23224594
File Transfer Average Throughput/Session: 342.3485107421875 6583.7021484375
Upstream Link Info
Loop Loss SNR Margin Errored Seconds Hec Errors Cell Count Speed
13 27 0 0 1060 443
Downstream Link Info
24 9 2 N/A  6095 8051
Downstream BIP Interface Data
Current Line Rate Line Rate Change TimeStamp Maximum Stable Rate Recalculated Profile TimeStamp Maximum Stable Rate Fault Threshold Rate Interleaving Flag
7150 18/12/2010 06:23:26 Y 01/11/2010 07:10:39 12480 9984 A
Jaggies
VPI: 0 0
VCI: 0 0
Are you sure? Should be VPI=0 and VCI=38.
skimanant
Are there any auto plusnet ways to update this? It could be the problem? I just copy and pasted it from the Plusnet Speedtest.
Jaggies
Those values should be stored in the router - it may be that the speed test site didn't read the information correctly, but then I've never seen that much detail in a BT speed test...
