Fastest FTTC upgrade?
- Fastest FTTC upgrade?
25-03-2014 10:27 AM
I've got to say I was pretty impressed with the speed of my upgrade this morning.
Engineer called at about quarter to nine to say he was at the cabinet. He'd done the work there and was at my door before nine. He'd got the faceplate changed and new modem connected in the time it took to make us a cuppa. As I was previously connecting via PPPoE, once he'd completed the line tests, I was able to plug my network back in and was up and running without needing to reconfigure anything.
I'm also the first on in the cabinet, which is nice.
My only concern is that his line testing kit and the BT speed checker reckon that I should be getting about 58-60Mbps downstream, I am only seeing about 35Mbps and the plusnet site says my line speed should be about there (37Mbps). The initial line speed estimate was about 30Mbps.
Soo.. which figure is what I should be seeing .. ~30Mbps or ~60Mbps? Is it a result of pre-configuring based on the initial estimate and will I likely end up seeing closer to the 60 figure?
I am seeing about 14Mbps upstream so this sort of suggests that the ~60Mbps is achievable.
Message 1 of 6
(979 Views)
5 REPLIES 5
Re: Fastest FTTC upgrade?
25-03-2014 10:39 AM
Are you on the 40/10 or 80/20 package?
If you are on the latter then it looks like they haven't enabled the 80 bit.
I am ~200m from my cabinet and get 78Mb down.
(From the router Line Rate (Down / Up) 79987 kbps / 20000 kbps)
It also needs to test the line and the speed will vary for the next few days anyway, but you should get more than 37Mb if you are on the 80Mb package. My quote is also 60Mb down.
Message 2 of 6
(632 Views)
25-03-2014 10:47 AM
I think I'm on 80/20. I don't recall being given an option, but my upload speed rules out 40/10 anyways. I'm just a little concerned that the 35Mbps d/l is due to some 'hard' configuration based on the speed estimate. If it is something that the PN systems will 'learn' over time, I'm happy to wait
Message 3 of 6
(632 Views)
25-03-2014 10:50 AM
If you run the BT Speed Test http://speedtest.btwholesale.com/ and then the Further Diagnostics. Can you post your downstream/upstream IP Profiles?
Also, can you post your speed estimates from here http://www.dslchecker.bt.com/ ?
Message 4 of 6
(632 Views)
25-03-2014 11:10 AM
Hi jaark,
I've just made some back end changes which should resolve the issue for you. Can you restart your router? This will push the changes into effect.
Message 5 of 6
(632 Views)
25-03-2014 11:48 AM
Awesome, I am indeed now getting just a smidge under 60Mbps
Many thanks Chris.
I had used that before (that's what I meant by BT speed checker), but thanks for the assistance.
Many thanks Chris.
Quote from: AndyH If you run the BT Speed Test http://speedtest.btwholesale.com/
Message 6 of 6
(632 Views)
