Face time problems
Anotherone
Champion
Fixes: 21
Re: Face time problems
HD streaming can be between 2 & 3GB per hour.
What security method have you got on your wireless rooky?
Have you ever given an old Plusnet modem/router of yours to any one else?
@KevinG
http://community.plus.net/forum/index.php/topic,112768.msg970439.html#msg970439 explained about profile and download speed so rooky could understand.
rookey
Nope not given anyone any router at all.
So this something i need to look into the TTB tracker doesnt use much does it?
Like I say daughter not been here to use the youtube so no streaming been done since monday
Also my security is highest we can do on the Wifi I believe and as stated I have altered my wifi password 3 times this week and made no difference
AndyH
TBB Graph:
Will this use up my usage allowance?
We only send very small ping packets every second. These are 28 bytes in size, so the total usage from our system would be 2.42MB (megabytes) per day, or on average around 73.63MB (megabytes) per month. Most broadband packages with usage allowances would measure them in Gigabytes (1000MB), so this would represent an insignificant amount in your usage allowance. If in doubt, please contact your service provider.
Running speed tests can add up as you're essentially downloading/uploading dummy files.
Anotherone
Champion
Fixes: 21
What about OS updates, phone updates, Anti-virus updates, Anti-malware updates and all that sort of thing?
rookey
No updates had happen to any of my devices the past 2 days I know that for a fact Smiley
Anyway going to see how things goes past few days Smiley
rookey
This Wireshark bloody confusing hope I know what I am doing  Lips_are_sealed
Anotherone
Champion
Fixes: 21
Yep, it is a bit of a .... to start with. Did you look at http://community.plus.net/library/tools/how-to-use-wireshark-osx-video/ ?
But hey, that's streaming as well which may account for some usage if you did  Huh
rookey
Only just downloaded Wireshark not too long ago to see how it works ready for when i have a facetime sessions.  IT OVER MY HEAD will have to go and look at the helps
Do I need to select a file extension to save it as which is best for your guys?
Anotherone
Champion
Fixes: 21
Have a play with it first. Choose an uncluttered directory (or a new one) to save the files in, they get quite big if you leave it running for very long.
You just save the files as is by Wireshark, and then the one that you need to send to Plusnet you zip up.
Edit: don't know if you read http://community.plus.net/library/faults/using-wireshark-for-data-capture/ also helpful  Wink
Pettitto
Fixes: 5
Does <a href="http://community.plus.net/library/tools/how-to-use-wireshark-osx-video/">this</a> help?
chuckster
Great stuff guys
