Face time problems
- Face time problems
Re: Face time problems
12-03-2013 8:26 PM
I appreciate you are having trouble, but that's more likely to be related to the peak time issues. Unless you are saying you can't use facetime at other times?
Ex-Broadband Service Manager
12-03-2013 8:29 PM
I could not face time on Friday at 2pm it was bad just like evenings. Is there any where that PN can reset my account? I can't understand you saying that graph look ok when I am hardly using the Internet ie out etc. a few guys on here are shock what my graph is showing.
Can you possibly check the ticket I am waiting reply for please?
12-03-2013 8:32 PM
12-03-2013 8:33 PM
You can have mine if you like !
It is quite colourful and a lot busier than yours, but I am not having anywhere near the problems you seem to have.
I have to agree with Kelly -
Quote I'm not seeing that as a dreadful graph
Mine isn't dreadful either, just that there are periods when mine should be better.
@rookey - have you read the ThinkBroadBand "How to interpret the BQM graphs" -
http://www.thinkbroadband.com/faq/sections/bqm.html
12-03-2013 8:34 PM
Quote from: Anotherone Totally agree there AndyH.
rookey, have you got a flat above the exchange? If not, it must be at the bottom of your garden!
You still haven't said what you were using at just after 4.00pm. I was hoping we might account for the Blue peak?
What you mean about flats.. The exchange is on it own in it own building..
At 4 I was out and the mrs said she was just browsing the net Ie news etc
12-03-2013 8:34 PM
Quote from: Kelly Rookey: I'm not seeing that as a dreadful graph.
Umm what?
Are you telling him he cant use his internet because its peak time? what if hes working 9-5?
12-03-2013 8:43 PM
Quote from: Blim
Umm what?
No, I'm saying that the problems he's seeing are likely to be the problem we are investigating and bumping the other threads/tickets he's got aren't going to speed it up.
Unless he's seeing performance issues outside of peak of course. I know Chris Pettitt was having a look at his line to today to check that though.
12-03-2013 8:44 PM
12-03-2013 8:48 PM
Quote from: Kelly
Quote from: Blim
Umm what?
Be nice to hear what Chris found or anything he think looks a bit dodgy.. I did ask is there such thing as resetting account ?
12-03-2013 8:54 PM
How about this for starters -
The Plusnet router is known to be OK for the ADSL, but widely reported as rubbish at WiFi.
Rookey is using FaceTime wirelessly on a portable Apple device, again not exactly known for good wireless performance (with non-Apple devices).
So for a start you have two wireless devices talking to each other which both potentially have issues.
So far nobody has suggested stepping through the wireless channels to find the best connection or a free slot.
Rookey has worse performance in the evening, so it could easily be a neighbour switching on their higher power WiFi swamping Rookies wireless connection to such an extent that it appears that there is a communication problem - which there is, but it's the wireless and not the broadband.
12-03-2013 8:54 PM
12-03-2013 8:57 PM
Quote from: purleigh I would hazard a guess that this FaceTime problem might not even be a broadband issue !
I have though many times of getting a apple airport but people said the router that PN provide won't work with it ???? As cant turn wifi odd on the PN router?
Saying that I have said many times I had no problem for the past years and it only started bady the past 3 weeks so it can't be a apple problem as I have used his router with ipad with no problem at all in the past..
I have selected a channel no one is using round here too
12-03-2013 8:59 PM
You aren't being ignored, that's fairly obvious. I did suggest somewhere in one of the threads that you posted in, that next time you get a Face Time problem, try connecting via Ethernet and see if the problem still remains. That way you might at least eliminate wireless. I expect you've got so het up you've probably forgotten that
PS.The bit about the flat above the exchange was a joke - you are obviously very close to it because those stats are very good
12-03-2013 9:00 PM
12-03-2013 9:01 PM
