FTTC but DL 3.5mb (ul is 17mb!)
- FTTC but DL 3.5mb (ul is 17mb!)
16-04-2013 8:49 PM
FTTC installed today, DL speed tested via web consistent (with 2 WAN routers) @ 3.5mb and UL at 17mb.
So... is this a line profile thing given the installation was in the last 12 hours or do I have a problem?
[edit]
BT checker says:
Download speed achieved during the test was - 3.3 Mbps
For your connection, the acceptable range of speeds is 16 Mbps-77.44 Mbps .
Additional Information:
IP Profile for your line is - 77.44 Mbps
Thanks!
Re: FTTC but DL 3.5mb (ul is 17mb!)
16-04-2013 9:26 PM
http://usertools.plus.net/@gateway/
What exchange?
http://www.samknows.com/broadband/exchange_search
16-04-2013 9:28 PM
You are currently connected to gateway ptn-ag01.
This is located in Telehouse North.
Poplar is the exchange, LNPOP
17-04-2013 9:31 AM
I'm really sorry to hear that you're suffering with poor Fibre speeds.
It looks as though your package hasn't been moved on our systems to FTTC. You will still be seeing poor speeds until this gets moved over. I've passed this over to Chris Purvey who is having a look into this for you. He'll pop a post on here shortly and get this sorted out for you.
17-04-2013 9:44 AM
We'll also place your phone line order today.
Let me know how you go.
17-04-2013 12:50 PM
Thats great thanks, I am now seeing 20mb DL. Hoping that will go up over the next few days!
17-04-2013 12:56 PM
Let us know how you get on
17-04-2013 1:02 PM
Quote I am now seeing 20mb DL. Hoping that will go up over the next few days!
Is that wired or wireless ? you need to try a wired test to confirm the real speed. Wireless speed may be reduced significantly by many factors.
17-04-2013 1:23 PM
Yip, wired, 1gb to my router
17-04-2013 2:26 PM
and I presume Chris has just set your PlusNet profile to a similar value, but you can check that here https://portal.plus.net/my.html?action=data_transfer_speed ( login required ).
Quote IP Profile for your line is - 77.44 Mbps
What's that value showing ?.
17-04-2013 2:31 PM
17-04-2013 2:49 PM
Estimated line speed: 57Mb (Accurate to within +/- 1Mbit) - Checked on 2013-04-17 10:39:12
Current line speed: 78 Mb
So it looks like I am at 78mb already, but BT speedtest shows;
Download speedachieved during the test was - 19.8 Mbps
For your connection, the acceptable range of speedsis 16 Mbps-77.44 Mbps .
Additional Information: IP Profile for your line is - 77.44 Mbps
So perhaps there is a "training" thing going on?
17-04-2013 2:58 PM
This smells like a fault to me! Chris and/or Chris will be investigating for you.
Ex-Broadband Service Manager
17-04-2013 3:00 PM
17-04-2013 3:31 PM
