FTTC Unlimited - Websites not loading and Up and Down Speeds
sharktech
Afternoon all
i did a search about the websites not loading and saw it was fixed but not for me, ive just joined plusnet on the unlimited package but cant get to a good chunk of websites i.e imgur.com, speedtest.net, caughtoffside.com and pinterest.com are good examples others load but then dont pull images in. i have tested with Plusnet, Google and BTs DNS Servers all resolve the a record fine but wont load the website.
On the speed side of things,
18/1/14 - 8:33am - 36mb d - 7.7mb u
19/1/14 - 9:15pm - 8mb d - 6.5mb u
19/1/14 - 2:53pm - 35mb d - 7.3mb u
20/1/14 - 9:59pm - 9.5mb d - 7.3mb u
As im on the unlimited i was told that i woudn't be subjected to the time/speed limitations than non unlimited are - is this wrong?
I dont use the thomson router as i have a sonicwall tz that does ppoe and i have connected my mac book directly to the bt nte and done a ppoe from there and its still the same.
also i have added the pro addon and this hasnt helped at all.
just read also that theres an issue at the exchange(Kidsgrove) so that might be causing all this - if not im going to have to go back to Bethere
Thanks in advance
12 REPLIES 12
AndyH
Re: FTTC Unlimited - Websites not loading and Up and Down Speeds
Yes....there is an issue with Kidsgrove/Alsager
Latest update is:
Quote from: dave
Latest updates:
Alsager/Kidsgrove - Capacity issue has been identified and they have ordered additional capacity into the exchanges. At the moment there's no ETA but we'll be escalating this up the chain and I'm talking to the BTR guys as well to see how many users they've got affected.
Furness area - no change since yesterday evening, ETA is still mid February.
adamwalker
Fixes: 221
That type of issue would affect broadband availability for new customers on that exchange but shouldn't pose any issues to existing ones.
@sharktech
I have to admit from what you've mentioned that this sounds like a browser issue. Have you tried another browser and can you describe what happens when your browser is trying to load the images.
 Adam Walker
AndyH
@ Adam I think you've misunderstood what dave has said. It's a bandwidth capacity problem, not a capacity problem for new connections.
30FTTC06
Fixes: 4
Quote from: sharktech
I also can't see how this would be a browser problem given that it is only bad in the evenings ?
sharktech
Apologies in the late reply
I have tried
macbookpro : Chrome & Safari
ipad mini : same
ipad 4 : same
iphone 5 & 5s : same
hp laptop : ie 9,10,11, chrome, safari and firefox
all the same, i have literally just joined plusnet, tuesday 15th was the install day,
One thing to note i have a 3g femtocell (unplugged it and still the same) when i disconnect from wifi and use 3g everything works fine, obviously slow but all pages/images load (o2 box creates vpn from the femtocell to o2)
sharktech
Quote from: 11110_110
speeds are bad as i posted but websites loading etc happens regardless
Cheers
AndyH
@ sharktech
Your problems will be caused by a bandwidth capacity issue at your exchange, PN have escalated it to their suppliers and are waiting for an update. Hopefully it will soon be fixed for you.
sharktech
Cheers Andy - just a bit funny that all plusnet sites load instantly lol
Cheers
dick:quote
jelv
Fixes: 10
When you have visited them once a lot of the files (images etc) will be in the browser cache and hence there isn't much to download so the pages will appear quickly. Try a CTRL F5 to refresh the page or a different browser (or clear the browser cache) when things are going slow and it might appear rather different.
You might also try http://www.mybroadbandspeed.co.uk/ which is a Plusnet site.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
sharktech
Jelv - clearing cache was the first thing i did - cheers anyway
dick:quote
sharktech
Quote from: AndyH
Latest update is:
Quote from: dave
Latest updates:
Morning
Where did you get the info above from, cheers
dick:green Quote fixed.
jelv
Fixes: 10
Click the links in the headers of the quotes!
