FTTC Questions
- FTTC Questions
- « Previous
- Next »
Re: FTTC Questions
22-08-2012 10:24 AM
Mike
Re: FTTC Questions
23-08-2012 12:56 PM
Mike
Re: FTTC Questions
23-08-2012 1:33 PM
Apologies for the delay in response. I have followed this up, we have raised a expedite request for this to get it as early as possible. We have been given an appointment date of the 29/08/2012 between 8am - 1pm.
Your ticket will get updated accordingly and I will arrange to refund your account for the time you have been without your service.
Apologies again for the delay and I will also monitor this to make sure everything is OK with your connection.
Chris
Re: FTTC Questions
27-08-2012 10:33 PM
Mike
Re: FTTC Questions
28-08-2012 11:34 AM
Re: FTTC Questions
29-08-2012 10:35 AM
All up and running again following todays engineer visit. Thanks for your help. IS it possible to change me over to the new 250Gb fibre extra. Had a look at product change but that still thinks there is no connection.
Mike
Re: FTTC Questions
29-08-2012 11:36 AM
We have had a minor problem with some fibre customers trying to upgrade their package. This should be resolved soon.
As soon as it is I will let you know and we can get you upgraded.
Chris
Re: FTTC Questions
31-08-2012 1:53 PM
Is the upgrade problem sorted?
Mike
Re: FTTC Questions
01-09-2012 8:58 AM
I suspect that the BT info is innacurate and is telling people they can get the 80/20 so they upgrade (not Plus Nets fault as I assume they use the same info) and then find there is no change. They end up paying for a product that isn't what they ordered.
Re: FTTC Questions
02-09-2012 8:10 AM
My estimate was 57/20 but I'm only getting 50/14, but most people will find they will get more than their estimate.
If you have a HG612 modem then it is possible to hack it and then obtain your attainable rate, this will show the maximum speed your line is capable of even if your on a 40/2 product.
This example is someone on a 80/20 product but they must be pretty close to the cabinet, I've even seen some with an attainable rate of over 131 meg downstream - they must literally be next to the cabinet.
Quote Max: Upstream rate = 33119 Kbps, Downstream rate = 88236 Kbps
Path: 0, Upstream rate = 20000 Kbps, Downstream rate = 79999 Kbps
Re: FTTC Questions
03-09-2012 10:05 AM
Your account change to our new Extra package is scheduled to go through on your next billing date.
Re: FTTC Questions
03-09-2012 8:50 PM
MIke
Re: FTTC Questions
04-09-2012 11:51 AM
Let me know if you need any further help.
- « Previous
- Next »
