FTTC Profile
- FTTC Profile
FTTC Profile
23-02-2012 3:48 PM
Reading through other threads I've seen posts regarding line profiles and just wondered if somebody from PN could check mine to ensure I'm getting the optimal performance.
Much appreciated.
David.
dick:green Image tags added.
Re: FTTC Profile
23-02-2012 4:04 PM
I have checked over your account and line and the results are as follows:
Downstream sync rate: 40Mbps
Upstream sync rate: 2Mbps
BT network profile (IP profile): 38716kbps
Plusnet network profile: 40000kbps
Don't forget you can check all these values yourself by running the BT speed tester at http://www.speedtester.bt.com/ (Downstream/Upstream sync rate and IP profile) and by clicking here: https://portal.plus.net/my.html?action=data_transfer_speed (Plusnet network profile).
Any questions just ask.
Re: FTTC Profile
23-02-2012 4:35 PM
PN removed some of the traffic management restrictions on the fibre packages (yesterday, I think), so you'd see better speeds in the evening.
However, at 15:30, that test ought to have worked better. Other things that might get in the way include use of wireless - have you been running the speedtest over WiFi, or with a wired connection?
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
Re: FTTC Profile
23-02-2012 4:37 PM
Re: FTTC Profile
23-02-2012 4:38 PM
Re: FTTC Profile
23-02-2012 4:45 PM
Note that the Leeds server seems to be giving really fast ping values, so gets selected for a lot of tests when you don't choose the server manually. However, it has also been giving some funny results over the last couple of days.
I usually choose the Newbury server myself. For some reason, this one seem to be the most consistent over different times of day.
Re: FTTC Profile
23-02-2012 6:36 PM
Quote from: Alex Downstream sync rate: 40Mbps
The BT speed test doesn't give sync speeds any more on WBC/WBMC lines Alex. I don't know about 20CN as I haven't been looking out for it.
Re: FTTC Profile
23-02-2012 8:07 PM
Re: FTTC Profile
24-02-2012 10:50 AM
Quote Seems like I will need to raise a ticket?
Rather than that I can see you've asked to be on the 80/20 trial so I've just put your order through, it should complete on Monday and router should with you within 3 working days.
Let me know how things go with that.
Adam
Re: FTTC Profile
24-02-2012 11:16 AM
and as to the above, i get 35mb, depsite my profile saying the same....
Re: FTTC Profile
24-02-2012 11:30 AM
http://community.plus.net/forum/index.php/topic,102776.0.html
@Estragon
You're right. I'll feed that back as it was extremely useful from a customer perspective especially since you cannot pull the sync rate from your BT modem directly.
Re: FTTC Profile
14-03-2012 7:13 PM
Connection Status Help
Mode VDSL2
Traffic type PTM
DSL synchronization status Up
DSL up time 1463053
Line Status
Downstream Upstream
Attainable rate (kbit/s) 58912 14417
SNR margin (dB) 13.6 18.7
Line attenuation (dB) 0 0
Output power (dBmV) 12.3 1.5
Statistics Help
Path 0 Path 1
Downstream Upstream Downstream Upstream
Line rate (kbit/s) 39997 1999 0 0
CRC errors 0 0 0 0
FEC errors 26928 123 0 0
HEC errors 7644 0 0 0
