FTTC Order
NewGuy20
FTTC Order
Well things are moving swiftly only with plusnet just over a week and now Fibre became available on my cab yesterday. I've ordered it by the product change page.
Only thing is when I looked at my closed questions I can't see anywhere that's it succeeded apart from this modify order unless that's it?
Provisioning of your ADSL Account Information
New Action 21CN Modify Submitted added
(via ADSL2+ Order System Interface)
22 REPLIES 22
chrispurvey
Re: FTTC Order
Hi NewGuy20,
I've checked over your order and there has been an issue with it, we're still in a position to get both services activated but it will not be simultaneous unfortunately. As it stands your phone line will complete first and then the fibre order will be placed, however, if you would prefer your fibre order to complete first I can place this orer and then arrange to bring your phoneline across once this has complete.
Apologies for the confusion with this.
Let me know how you'd like to progress with this.
Chris
NewGuy20
Re: FTTC Order
Hi Chris,
Can we do the fibre first then the phone line
Appreciate your help on this
chrispurvey
Re: FTTC Order
No problem at all, I'll confirm this with you later today when it's all gone through.
chrispurvey
Re: FTTC Order
I tired to call you to discuss this with you.
Your fibre order is now booked in for the same date as it was (29th April 1pm-6pm)
I hope this is OK for you? We'll place the phone transfer as soon as your fibre install has completed.
NewGuy20
Re: FTTC Order
Ah saw I had a missed call i was outside didn't take the phone Sad
Thanks for your can do approach with this one. That date dont really fussed date wise apart from the sooner the better  lol
I take it even though the order has been done manually everything else will proceed as normal e.g router delivery etc.
Thanks again
chrispurvey
Re: FTTC Order
I called to check the best install date for you, I've managed to move that the 26th April 1pm - 6pm I hope that's OK?
NewGuy20
Re: FTTC Order
Chris,
I'm really sorry thats about the only day I can't do unless it was AM on Friday otherwise any other day is fine.
Sorry to mess you about.
NewGuy20
Re: FTTC Order
Not to worry spoke to Ollie and he changed it back to 29th for me.
chrispurvey
Re: FTTC Order
Just about to do that for you Smiley
NewGuy20
Re: FTTC Order
Hi Chris,
Could someone check that my FTTC will be with me on Monday morning? Just checking not sure if all the date changes but have confused the router order.
chrispurvey
Re: FTTC Order
It's is booked in for the 29th although it's booked for 1pm-6pm, is that OK for you?
NewGuy20
Re: FTTC Order
Yeah the appointments fine just wanted to make sure I got the router before the BT OR guy turns up
adamwalker
Fixes: 221
Re: FTTC Order
Thanks for letting us know.
 Adam Walker
NewGuy20
Re: FTTC Order
Adam
Can you confirm it will sent out today?
