FTTC IP profile
- Re: FTTC IP profile
FTTC IP profile
13-05-2011 7:39 PM
I had value FTTC installed yesterday the engineer tested the line and said it was capable of 40mbps i know that i'm not going to get that speed.
I carried out a bt speed test and got 20mbps with a ip profile of 38.
Does my PN IP profile need to be updated?
How do I check my PN IP profile as I did find a link before but can't find it now?
My account is still showing my old package.
Can you add pro to this FTTC and does it lower the allowance? and would it make any difference?
Sorry to ask so many questions.
Thanks in advance
Steve
Thanks in advance
Steve
Message 1 of 6
(835 Views)
5 REPLIES 5
Re: FTTC IP profile
13-05-2011 9:09 PM
It should be 20 (old figure) or 37 )new figure) for FTTC/FTTP.
Message 2 of 6
(470 Views)
Re: FTTC IP profile
13-05-2011 10:13 PM
Also how long can the LAN cable be between the modem and router be I think the one from the master socket to the modem can be 30 meters but no mention of the LAN as I may keep the modem next to the master socket and move the router to other place via a LAN extension set up I have to get a better wireless connection.
Message 3 of 6
(470 Views)
Re: FTTC IP profile
13-05-2011 10:35 PM
Cat5e 100Mbit LAN cables can be 100 Meters between stations.
Message 4 of 6
(470 Views)
Re: FTTC IP profile
14-05-2011 8:04 AM
It's 100M of Cat 5E ethernet, but only where the bulk of the distance is done using the solid-core cable normally used for in-building installation (eg 90M solid core, plus 2*5M flexible patch cable).
If you just use the flexible patch cable, then the maximum is said to be 30M - which is generally the largest length you can buy.
Plusnet Customer
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
Message 5 of 6
(470 Views)
Re: FTTC IP profile
14-05-2011 9:52 AM
I've got cat 6 soild external cable just under 30m so that should be ok. I'll get through the 1st ten days of connection then give it a go.
cheers
Steve
cheers
Steve
Message 6 of 6
(470 Views)
