FTTC Download OK, upload very slow
Stoker
I see a few other people have mentioned this in the past, but without saying if/how it was sorted.
We're around 900m from the fibre cabinet so don't expect 40/10, but we did settle for around 27mbps down and 4mbps up for something like two years. After a loss of service a few weeks ago was fixed, we now get the same download speed, but only 600k to (at best) 1m upload.
Have had several Openreach visits and they can't fins any faults. They've moved us to different ports ("lift and shift") and then onto a different line card, but it's made no difference. Openreach engineer has run out of ideas, but does say we should be getting over 30mbps download (original Plusnet estimate was 33mbps +/- 1%) and 6-8mbps upload.
Does anyone have any suggestions?
(open ticket 89262460)
70 REPLIES 70
Stoker
Re: FTTC Download OK, upload very slow
Just noticed that my Plusnet speed profile says 78mbps. Although I'm on Fibre Unlimited  I remember being told my profile would stay at 40/10 because I'm too far from the cabinet to get 80/20.
Stoker
(Not sure why other people with a very similar problem get a response here and I'm ignored).
Anyway, my ticket's reply blames crosstalk. I'm not convinced. Someone, please, tell me that  28mbps download and 600kbps upload is not normal.
LukeS
Hi Stoker,
We don't officially work the forums at the weekends and I apologise you received no response yesterday. First of all, it is entirely possible that your seeing reduced speeds due to crosstalk. However, your upload speeds are unacceptable and the reason they are so low is because they are capped. DLM on FTTC is so complicated there aren't many people on the planet that fully understands it. However, what I can tell you is that as long as you have disconnections, whether it's you or a faulty connection then speed will never improve.
<img src="http://community.plus.net/visualradius/generated/image14075854665997.png"/>
It's possible that some of these disconnections have been caused by yourself. I suggest not touching the modem and monitoring for a few days. If you're still seeing disconnections an engineer will need to be sent out to have a look at the drops in connection rather than the speed. Once you have a stable connection for a certain time (Could be anything between 8 days and 64 days) then the speed will increase. If an engineer makes a physical change to the network, we can ask them to manually reset the line which would increase the speed immediately.
Terranova667
Fixes: 5
I wouldn't say 8 - 64 days for a increase is correct I have been waiting 3 months now fro DLM to increase after a fault on my line was cleared and it's done nothing despite tests showing it to be green, why not be more realistic and say it's most likely you wont see your full speed again if your relying on DLM to do it, A reset is the only way your going to see full speed again pray the issue is bad enough for it,  sadly mine wasn't i have had to pay the price for that.
LukeS
Hi Terranova667,
We're not able to do DLM reset's on FTTC unless an engineer makes a change to the network (Changes the pair etc..) I'm happy to have a look at your account on Monday if you'd prefer. I'm interested to find out what's going on with your connection but I'm leaving the office shortly..
Terranova667
Fixes: 5
Hi luke yeah i'm aware that a reset cant be done unless network changes are made that was one of the let downs i had when the fault was fixed as it didn't require network changes to solve it so no reset, i was told i had to rely on DLM to make the change.
I would be grateful if you could take a look on Monday as i say it's been 3 months and not a single increase, I use to sync at 65Mb profiles at 63.5 Mb before the fault , when i got the fault it dropped to 60Mb after three engineer visits to find the problem and due to them disconnecting the modem each time to run tests etc  DLM dropped it down to its current 59Mb sync 57Mb profiles, it's remained that way since even after the fault was sorted out and tests showing the line to be green. I did ask if profiles can get stuck but was told it hasn't been seen on Fibre so i dunno
Stoker
Thanks guys.
> ... as long as you have disconnections, whether it's you or a faulty connection then speed will never improve.
The disconnects all last week (Monday to Thursday) were Openreach engineers working on the problem! Yes, they were here on-and-off for four days and told me they could find nothing wrong with my line as far as the cabinet, but did see a high resistance at the cabinet (900 metres away).  That prompted ...
> ...We're not able to do DLM reset's on FTTC unless an engineer makes a change to the network (Changes the pair etc..)
That was done - a "lift and shift" (?) on Wednesday and a line-card move on Thursday. The engineer did tell me that he'd requested some kind of  reset after the changes, but he wasn't sure that happened correctly. He knew they'd done something wrong the first time he asked ...
As I've mentioned in my ticket, we got around 4mbps upload for at least a year until a fault happened a few weeks ago. The BT DSL checker says we should get 5.8mbps upload (low range B) which is supposed to allow for crosstalk. That's why I don't think 600kbps is acceptable. The 4mbps we were getting I can live with
GeordieMark
It may well have failed, the OR guy who came to look at my FTTC the other day had to try about 5 times before it would successfully reset, from what he was saying a lot of the tests etc they do seem very unreliable  Tongue
LukeS
@Stoker
We have to contact a different department at BT (By email) to ask them to reset the DLM profile remotely. I've asked the question and as soon as I hear anything I will be in touch. Alternatively, we may need to arrange a further engineer.
@Terranova
Your line appears to be operating with the accepted range. - Down 38.2 & Up 7.7 are the estimates according to https://www.dslchecker.bt.com/. Your banding is currently: 37M-74M Downstream, Interleaving Off - 7.5M-15M Upstream, Interleaving Off. Which is the highest it will go to with your current sync speed.
Stoker
Many thanks. Would you agree that 600kbps (or less) upstream is NOT in the accepted range? So far no-one from Plusnet has.
That's my complaint. Downstream is OK and upstream was too until a fortnight ago.
Actually I don't think I should be banded 37-74m down, 7.5-15m up; I know I will never get close to that because of my distance from the cabinet.
When I switched to fibre unlimited I was told I'd stay on the 40/10 profile rather than 80/20 for that very reason. I only switched to remove the 40GB a month cap.
LukeS
Hi Stoker,
That banding profile was aimed at Terranova for his/her connection. Can you confirm what your upload speed was previously? Please see below the response I received from BT verbatim :-
in sync at 29 meg down and 800k up  the downstream  is correct, the max rate on RRT is 29 meg, so this will not attain higher.
The upstream max rate however is 2 meg, and yet it will only sync at 800k, this is because of crosstalk on the line and there is nothing we can do about that
In short the profile request from the engineer did go through and there is no capping on the line.
Upstream not achieving expected speed due to cross talk on the line.
Stoker
Oops sorry  misread.
As I said I was getting around 4mbps upload until a fortnight ago.
Fixes: 395
AFAIK the Fault Threshold Rate (FTR) for upstream on a 10Mb provisioned line is the higher of 22.5% of the downstream sync or 2Mb. Your upstream, Stoker, is cleary well below that!.
LukeS
That's annoying. The problem with FTTC is we have little control at this end. I've gone back to BT and been quite forceful. We may have to try something more drastic if that doesn't work.
