FTTC: BT Wholesale's Green screen of death
- Re: FTTC: BT Wholesale's Green screen of death
02-11-2011 12:46 PM
Hi all; long time since I popped in!
We have an FTTC connection that works well in all respects, except for one: We get the "BT Wholesale Green screen of death" when browsing onto a new website - the one that reports that:
We get these at irregular occasions (perhaps once every one or two weeks), and usually have to get the router to disconnect & reconnect to fix things - but this isn't always enough. Sometimes it takes 4 or 5 re-connects to work... and sometimes I just give up.
An interesting thing to note is that this appears to be a problem with DNS only - browsing a site where the DNS name has been cached will continue to work - so new pages come up OK, and videos can be watched.
Searches on the forum suggest that a fix is to hard-code Plusnet's DNS servers into the router. However, I have a different setup (a caching name-server running on a Linux box) that already does this: It ignores the information in the router, and goes direct to either 212.159.6.9 or 212.159.6.10 for addresses that are not in the cache. I also restart this name-server whenever I re-connect the router, just to make sure I dislodge the fake BT address.
This is happening often enough now to be a little frustrating, with a particularly annoying episode yesterday lunchtime. Does anyone have any other clues, or things to try?
Plusnet Customer
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
Message 1 of 5
(2,220 Views)
4 REPLIES 4
02-11-2011 1:18 PM
Hi WWWombat,
I've only seen this because of the DNS settings in the router. Is it not worth setting these anyway just in case there are times when it refers to them?
Jojo
Quote from: WWWombat Searches on the forum suggest that a fix is to hard-code Plusnet's DNS servers into the router. However, I have a different setup (a caching name-server running on a Linux box) that already does this: It ignores the information in the router, and goes direct to either 212.159.6.9 or 212.159.6.10 for addresses that are not in the cache.
Jojo
Message 2 of 5
(525 Views)
02-11-2011 1:26 PM
Hi Jojo,
You're right - it probably is worth doing the change anyway...I've set it to "Use These DNS Servers" instead of "Get Automatically from ISP"; it had the correct two addresses already.
We'll see if anything happens over the next few weeks...
Mike
Mike
Plusnet Customer
Message 3 of 5
(525 Views)
02-11-2011 4:10 PM
Bit of a shot in the dark to be honest, Mike, but always worth a try. Let us know if you get any more issues with it.
Jojo
Jojo
Message 4 of 5
(525 Views)
29-11-2011 11:57 PM
Hi Jojo,
I thought I'd send an update here....
It looks like the change to the router's DNS servers has indeed fixed things.... I've seen none of the dreaded green-warning-screens in the 4 weeks since I made the change, whereas I was getting almost daily occurrences beforehand.
I've no idea *why* it worked, as the computers were set to never query DNS through the router, but it does seem to have had an effect.
Mike
Mike
Plusnet Customer
Message 5 of 5
(525 Views)
