FTTC 1 year on
- Re: FTTC 1 year on
FTTC 1 year on
23-03-2014 7:30 PM
Is it possible for someone to look at my line, my fttc is the slowest it has ever been
in member centre
Estimated line speed:
Current line speed:
17 Mb
cant remember the last time i ever achieved 17mb i should be so lucky lol
BTW
1. Best Effort Test: -provides background information.
Download Speed
11.5 Mbps
0 Mbps 17.34 Mbps
Max Achievable Speed
Download speed achieved during the test was - 11.5 Mbps
For your connection, the acceptable range of speeds is 12.14 Mbps-17.34 Mbps .
Additional Information:
IP Profile for your line is - 17.34 Mbps
Upload Speed
3.88 Mbps
0 Mbps 10 Mbps
Upload speed achieved during the test was - 3.88Mbps
Upstream Rate IP profile on your line is - 10 Mbps
the above is a copy of speedtest results since fibre installed upto today, i did have issues in beginning which plusnet helped with and done all they could which led me to find out that even though there is a bunch on new fibre cabinets around, im currently connected to a cabinet 1 mile away with exchange another mile from cabinet (2miles from house) and apart from moving there is nothing that can be done.
i know that plusnet are not responsible for my physical connection but i think it is time that someone is held responsible i.e BTW, im fed up with the advertising of UPTO speeds, surely in this day and age that when you choose fibre a new line should be installed to the closest cabinet to give you a chance of actually achieving these UPTO speeds, as you can see im getting a quarter of what im paying for, 40/10 or even an eigth if you consider 80/20. Perhaps it may be time consider paying for speeds you actually get rather that what someone says you may be able to get.
in member centre
Current line speed:
17 Mb
BTW
Download Speed
11.5 Mbps
0 Mbps 17.34 Mbps
Upload Speed
3.88 Mbps
0 Mbps 10 Mbps
Message 1 of 7
(1,334 Views)
6 REPLIES 6
Re: FTTC 1 year on
23-03-2014 7:32 PM
also recently i have been experiencing wifi on Technicolor TG582n router cutting out, i can accesss the router page through wired pc which then seems to push wifi back on
Message 2 of 7
(694 Views)
Re: FTTC 1 year on
25-03-2014 10:34 AM
would really like plusnet to have a quick look at line please
as i said in original post speeds just seem to be decreasing over time
speedtest as of today
FAQ
Results Image not loaded
Download Speed
11.45 Mbps
0 Mbps 17.34 Mbps
Download speedachieved during the test was - 11.45 Mbps
For your connection, the acceptable range of speedsis 12.14 Mbps-17.34 Mbps .
Upload Speed
3.83 Mbps
0 Mbps 10 Mbps
Upload speed achieved during the test was - 3.83Mbps
This test was not conclusive and further testing is required.This might be useful for your Broadband Service Provider to investigate the fault.
If you wish to carry out further tests,please click on 'Continue' button.If not, please close the window using 'Exit' button and contact your ISP for further assistance with these results.
FAQ
Download Speed
11.45 Mbps
0 Mbps 17.34 Mbps
Upload Speed
3.83 Mbps
0 Mbps 10 Mbps
Message 3 of 7
(694 Views)
Re: FTTC 1 year on
25-03-2014 10:36 AM
BT BROADBAND AVAILABILITY CHECKER
Telephone Number *********** on Exchange ARDROSSAN is served by Cabinet 3
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
High Low High Low
FTTC Range A (Clean) 22.5 16.4 3.9 2.3 -- Available
FTTC Range B (Impacted) 19 8.8 3.7 0.7 -- Available
WBC ADSL 2+ Up to 3 -- 2.5 to 6.5 Available
WBC ADSL 2+ Annex M Up to 3 Up to 0.5 2.5 to 6.5 Available
ADSL Max Up to 3 -- 2 to 5.5 Available
WBC Fixed Rate 1 -- -- Available
Other Offerings
Fibre Multicast -- -- -- Available
Copper Multicast -- -- -- Available
Message 4 of 7
(694 Views)
Re: FTTC 1 year on
25-03-2014 10:41 AM
Hi paulflood,
I've just checked your line and got the following results:
Downstream Speed: 17.9 Mbps
Upstream Speed: 4.3 Mbps
Profile Band: 11.2M-22.4M Downstream, Interleaving Low - 2.5M-5M Upstream, Interleaving Off
From what I can see, the speeds look about right, given your speed estimate. Do you get similar results to those seen connecting directly via <a href="http://community.plus.net/library/broadband/fibre-help-how-to-set-up-a-pppoe-dialler-in-vistawindows-7/">PPPoE</a>?
Message 5 of 7
(694 Views)
Re: FTTC 1 year on
25-03-2014 10:43 AM
Are you running those speed tests wired or wirelessly?
You are still within the speed estimates of your line. Unfortunately, cross talk can have quite a negative impact on line performance and a some people do see decreased levels of performance as their cabinets fill up. This is one reason why there is quite a big range given in those speed estimates.
Message 6 of 7
(694 Views)
Re: FTTC 1 year on
25-03-2014 11:27 AM
first image is speedtest using ppoe method showing 16mb download
second image is when i reconnected the router which is now also showing 16mb lol
@andyh yeah all tests are done wired
Message 7 of 7
(694 Views)
