FEC error surge
- Re: FEC error surge
FEC error surge
08-04-2015 9:44 AM
Thanks in advance.
Re: FEC error surge
08-04-2015 9:58 AM
Re: FEC error surge
08-04-2015 10:25 AM
Re: FEC error surge
08-04-2015 11:27 AM
2. Yes Anotherone I was in fact (and still am..at my speeds !!) downloading a 3.5GB file
Re: FEC error surge
08-04-2015 11:33 AM
It actually isn't anything to worry about
Can you check the CRC and HEC errors which aren't corrected
Re: FEC error surge
08-04-2015 11:41 AM
If you are using the 582n, it doesn't report the uncorrected errors to answer Jim's question.
Re: FEC error surge
08-04-2015 11:49 AM
FEC Errors (Up/Down): 36,065 / 734,893
CRC Errors (Up/Down): 419 / 6,624
HEC Errors (Up/Down): 730 / 107,261
Re: FEC error surge
08-04-2015 12:37 PM
In which case, I would have thought it would just be a lot easier to post the TG582n Full DSL stats which gives them and a broader overview of things as we have the Uptime as well.
Re: FEC error surge
08-04-2015 1:06 PM
Re: FEC error surge
08-04-2015 1:38 PM
Quote from: Oldjim Can you check the CRC and HEC errors which aren't corrected
Maybe I just read it too fast whilst trying to be helpful to jjaycee1 having already written my post apart from the last line. I'd already explained in reply #7 why I found it confusing. I find your link to kitz patronising as I'm very familiar with it as you well know.
So the reason for your last reply is beyond me - may it's just another of your digs at me which you seem to enjoy whenever you get the opportunity. I'll leave this thread to you.
Re: FEC error surge
08-04-2015 2:53 PM
Quote Can you check the CRC and HEC errors which aren't corrected
To which you replied
Quote If you are using the 582n, it doesn't report the uncorrected errors to answer Jim's question.
To which I replied that it did
As you are familiar with CRC and HEC which are errors where the package has to be resent because the errors are not corrected unlike FEC which doesn't require resending then I don't understand why you posted what you did unless you were having a go at me
This isn't helping the poster
Endof
Re: FEC error surge
08-04-2015 3:14 PM
