F9/plusnet unlimated to plusnet premium speeds & traffic shaping
- F9/plusnet unlimated to plusnet premium speeds & t...
Re: F9/plusnet unlimated to plusnet premium speeds & traffic shaping
26-02-2010 12:41 PM
Seems stats changed again in the early hours.......
BT
Download speedachieved during the test was - 5193 Kbps
For your connection, the acceptable range of speedsis 600-7150 Kbps.
Additional Information:
Your DSL Connection Rate :6831 Kbps(DOWN-STREAM), 647 Kbps(UP-STREAM)
IP Profile for your line is - 5500 Kbps
26-02-2010 1:31 PM
Fastest connection yet although it still seems on the lower side for a 37 line attenuation.
Downstream Upstream
SNR Margin : 6.1 5.9 db
Line Attenuation :37.0 25.0 db
Data Rate : 7116 1031 kbps
27-02-2010 10:35 PM
Noticed that the Downstream SNR has dipped down into the 3's (stable connection though)
PPP connection time : 1:03:04:51 ( 1 day 3hours 4mins 51 sec)
Modulation : ADSL2 PLUS
Annex Mode : ANNEX_A
Downstream Upstream
SNR Margin : 3.6 5.0 db
Line Attenuation : 37.0 25.0 db
Is this normal for ADSL2+ for the SNR to fluctuate as much ?
I know on the capped 20CN it never really moved of 6
27-02-2010 10:44 PM
Uptime: 7 days, 5:34:11
Modulation: G.992.3 annex A
Bandwidth (Up/Down) [kbps/kbps]: 959 / 3.069
Data Transferred (Sent/Received) [MB/GB]: 353,16 / 1,28
Output Power (Up/Down) [dBm]: 12,5 / 0,0
Line Attenuation (Up/Down) [dB]: 27,5 / 48,5
SN Margin (Up/Down) [dB]: 5,5 / 3,5
01-03-2010 2:30 PM
Bit disheartened today with the speeds.
Been running rock soild for 3 days at over 7100kbps then around 6/8 am (again) it resync'ed at 6400.
So any Line profile increase has gone out the window again.:(
Just reset things again & its only 6500
Live line stats
Downstream Upstream
SNR Margin : 6.1 9.4 db
Line Attenuation :38.0 25.0 db
Data Rate : 6531 888 kbps
BTspeedTest
Download speedachieved during the test was - 1627 Kbps ?
Your DSL Connection Rate :6531 Kbps(DOWN-STREAM), 888 Kbps(UP-STREAM)
03-03-2010 2:43 PM
It starting to confuse me on why the sync is now the same as it was at the start of this thread on 20CN ?
The line stats have improved , the SNR is stable around 6 in the daytime & line atten has dropped from 42 to 37 / 38.
Yet downstream sync speed still around 6500kpbs ??
Line stats
Downstream Upstream
SNR Margin : 6.0 5.9 db
Data Rate : 6552 1000 kbps
Raised a ticket to ask 21CN faults tearm just to check things.
Thanks f9o
(Ticket ID: 32307358 if it helps)
04-03-2010 8:24 PM
DMT has the Bit loading data ?
04-03-2010 9:46 PM
If downstream is switched off then may get the same increase as happen with upstream from 444kbps to over 1100 kbps?
thanks again f9o
05-03-2010 5:30 PM
However since you have synced above 6656kbps it seems unlikely you are on a banded profile.
Have you had any feedback from your ticket?
David
05-03-2010 7:17 PM
Thanks for taking a look at the stats ...
I'm not 100% sure yet that I know what I'm doing with DLM tool but I'm trying to learn with help what I can.
Nothing back from CSC yet I guess 21CN teams been busy with central capacity upgrades. (PN seem to have had a outage around late after noon so I switched everything off of an hour or two. )
The Speedtouch has pre 6.0 flimware so I could change the target SNR but I didn't want to do that just yet?
Live line stats
ptime: 0 days, 0:26:48
Modulation: G.992.5 Annex A
Bandwidth (Up/Down) [kbps/kbps]: 1.044 / 6.470
Line Attenuation (Up/Down) [dB]: 22,0 / 40,5
SN Margin (Up/Down) [dB]: 6,0 / 6,0
Still seems like the 20CN BT cap is in place.
Thanks again f9o
05-03-2010 8:35 PM
Output power does that look right ?? ( again don't want to use area 51 yet)
From kitz
"With adsl2+ most lines will be running to their maximum capability, and a figure of around 18-19 dBm is the norm."
line data
Output Power (Up/Down) [dBm]:12,5 / 0,0 ?
Interterleaved path
f9o
06-03-2010 4:15 AM
Thanks for your message. ID: 32307358
So that we can further investigate this issue we will need you to run the BT Speedtester service, so that we can confirm the speed of the physical connection.
This test needs to be run 3 times, preferably one test in the morning, one in the afternoon and a final test as late in the evening as possible.
Once you have done this, if you could reply to this ticket with the results of the 3 tests, we can then get this investigated further and if necessary, escalated to BT.
Not More Speed testing
Download speedachieved during the test was - 5419 Kbps
Your DSL Connection Rate :6469 Kbps(DOWN-STREAM), 1044 Kbps(UP-STREAM)
IP Profile for your line is - 5000 Kbps
Download speedachieved during the test was - 5311 Kbps
Your DSL Connection Rate :6653 Kbps(DOWN-STREAM), 758 Kbps(UP-STREAM)
07-03-2010 1:34 PM
Having a downstream output power of 0.0dBm is nothing to worry about. That is a 'feature' of the Thomson on ADSL2+; I think it means it's at the maximum value (which is normal).
07-03-2010 2:14 PM
Is that 12.5dBm on the low side ? When reading Kitzs, 18-19 dBm is the norm for adsl2+ running at maximum capability?
I think your right on the banded profile or some other cap. Seems to be syncing around that key 6654kbps.
Noticed the SNR figures have increased to 7 & 8 ( maybe weather related ?)
Live line stats
Uptime: 1 day, 6:28:03
Bandwidth (Up/Down) [kbps/kbps]: 759 / 6.654
SN Margin (Up/Down) [dB]: 8,0 / 7,0
BTspeedtest
Download speedachieved during the test was - 5590 Kbps
f9o
07-03-2010 7:33 PM
Thanks for this I am passing this over to the correct team, we will email you again in due course.
That was faster the usual on the ticket speed ....
Mand & the rest of the team must be getting back on top of things
Should I also ask to get downstream interleaving knocked off as well. ?
f9o
