Extremely Slow service for the last 48 hours...
- Extremely Slow service for the last 48 hours...
Re: Extremely Slow service for the last 48 hours...
01-02-2011 5:14 PM
01-02-2011 5:38 PM
I've requested the reset now. I'll check it later, after my tea
Jojo
01-02-2011 6:23 PM
just ran routerstat and the noise is sitting between 6~6.5 line speed is up and back to what it was
01-02-2011 8:05 PM
It's about to get better! I've just lifted it from 4000k to 6000k which you should see shortly.
Jojo
01-02-2011 9:15 PM
If you wouldn't mind looking into adsl2 for me when u can that would be great. Must dash tho work in 6 hours.
01-02-2011 9:24 PM
If it shows a significantly higher speed it's worth going for the upgrade. If it's not a lot better I'd suggest you stick where you are.
01-02-2011 9:31 PM
Quote Downstream
Attenuation 29 dB Approx
Line Length 2.1 km
dslMAX 8128 kbps IP Profile 7150 kbps
adsl2+ (21CN) 16000 kbps IP Profile 14000 kbps
adsl2+ (LLU) 16000 kbps Throughput 14160 kbps
01-02-2011 10:12 PM
It looks like you are not achieving the expected sync for your attenuation - I think I'd suggest investigating why that is first!
Could you post your router stats please (sync speed, attenuation and noise margin).
02-02-2011 9:15 AM
As jelv says you should see a better sync rate than your current 6944k with an attenuation of 29dB and SNR of 6dB. How is set up wired?
Jojo
02-02-2011 3:01 PM
02-02-2011 4:11 PM
02-02-2011 4:16 PM
03-02-2011 2:34 PM
03-02-2011 3:42 PM
You need to be sure about that filter - using anything unfiltered on another extension WILL cause problems.
Can you make a note of the router stats (sync speed, attenuation and noise margin) then take the front off the main socket and put the router in to the test socket. Then take the stats again.
Post back with the before and after.
You should also confirm that when you are using the test socket the extension is dead.
04-02-2011 11:29 AM
Just so you know what you're looking for here is a picture of the test socket. You should just have the filter directly into there.
Jojo
