Explain This Plus-Net! 138 Ping
James1991
Im trying to play fifa 10 and its 8.45pm!!!!
During the day its fine ping at 40 today
Plusnet need to explain to me why this is like this?
Ive had Aol, Bt, and never had problems,
I want this sorted out plusnet or i will be leaving to another ISP, !!!
jimShockedrange all caps in title removed as per forum rules mod:end
52 REPLIES 52
James1991
Re: Explain This Plus-Net! 138 Ping
Rather then edit my caps , Please reply!!!
Have you checked your exchange? It could be overloaded (like mine is)
http://usertools.plus.net/exchanges/
Is what I get. But their ping figure is crazy. If I ping several sites based in the UK. I get an average of about 42 ms. If I ping sites in the US they come in at about 167ms
James1991
VP capacity at this exchange is currently showing as Green.
Click here for further details
BT have advised that this exchange is enabled for WBC on 21CN
You can view recent Service Outages for this exchange here
BT has published DSL Max upgrade information for this exchange
Any of that?
Sorry not sure what to do.
James1991
Can i change any tech details to get lower ping
Its just so crazy! after 8pm i cant play any games,
If not i WILL be cancel my plusnet.
Extreme0
Quote from: SteveA
the London Speedtest.net Server always has a bad ping,  Try another server.
James1991
Birmingham, WHAT CAN I DO TO LOWER THIS, AS ITS DRIVING ME CRAZY-AND I WILL BE CANCEL PLUSNET IF I CANT FIX MY GAMING SIDE.
Mand
Can you post a traceroute of a server you're having problems with?
You do this by opening a command prompt window (start > run >cmd), then typing tracert www.domain.co.uk and pressing enter.
This will point us in the right direction of the problem.
James1991
Done, cant seem to copy this info its showing though.
Extreme0
Type in Tracert www.domain.co.uk > C:/Tracert.txt
The Tracert File will be in your local disk.
head to my computer > local disk.
James1991
Tracing route to domain.co.uk [213.155.64.209]
over a maximum of 30 hops:
  1    1 ms    1 ms    1 ms  192.168.0.1
  2    19 ms    21 ms    19 ms  lo0.plusnet.thn-ag2.plus.net [195.166.128.93]
  3    21 ms    17 ms    19 ms  vl604.thn-gw1.plus.net [84.92.4.169]
  4    48 ms    18 ms    20 ms  te2-3.thn-gw2.plus.net [212.159.1.58]
  5    19 ms    19 ms    24 ms  vl23.pte-gw2.plus.net [212.159.4.28]
  6    20 ms    21 ms    39 ms  LINX1.LON-2.uk.lambdanet.net [195.66.224.99]
  7    49 ms    40 ms    40 ms  PAR-4-pos300.fr.lambdanet.net [82.197.136.34]
  8    37 ms    37 ms    36 ms  FRA-1-pos212.de.lambdanet.net [82.197.144.21]
  9    34 ms    35 ms    36 ms  FRA-3-eth100.de.lambdanet.net [217.71.96.70]
10    70 ms    51 ms    51 ms  NUE-2-eth210.de.lambdanet.net [217.71.96.162]
11    67 ms    42 ms    65 ms  Gi-0-1-124-rt1-nbg.core.noris.net [217.71.107.182]
12    43 ms    49 ms    48 ms  vl654-rt1-muc7a.core.noris.net [213.95.0.229]
13    61 ms    44 ms    81 ms  redirect.partnergate.de [213.155.64.209]
Trace complete.
reserved
When you get the tracert result, right click & select all - then paste the result here:
eg Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Owner>tracert www.bbc.co.uk
Tracing route to www.bbc.net.uk [212.58.251.195]
  1    38 ms    99 ms    99 ms  dsldevice.lan
  2    20 ms    16 ms    44 ms  lo0-plusnet.pte-ag1.plus.net [195.166.128.64]
  3    18 ms    20 ms    17 ms  ge0-0-0-403.pte-gw2.plus.net [84.92.4.2]
  4    17 ms    16 ms    15 ms  vl23.thn-gw2.plus.net [212.159.4.20]
  5    18 ms    17 ms    18 ms  rt0.thdo.bbc.co.uk [212.58.239.25]
  6    17 ms    18 ms    17 ms  212.58.238.149
  7    16 ms    16 ms    19 ms  212.58.239.62
  8    16 ms    16 ms    16 ms  www-vip.telhc.bbc.co.uk [212.58.251.195]
Trace complete.
James1991
Ive posted results-thanks.
Mand
Sorry, instead of domain.co.uk I need you to enter the server you're having problems with (I used domain.co.uk as an example).
What does pingtest ( http://www.pingtest.net/ ) show?
this is what it gives for me:
