Exchange being upgraded to 21CN, quick question
- Re: Exchange being upgraded to 21CN, quick questio...
04-04-2013 11:22 AM
My exchange is being upgraded to 21CN WBC in a couple of months. Does anyone know if I will automatically (or after a router reboot) start seeing the benefit once it is upgraded, or will I need to notify Plus.net so they can make changes?
Cheers
Cheers
Message 1 of 4
(761 Views)
3 REPLIES 3
Re: Exchange being upgraded to 21CN, quick question
04-04-2013 11:29 AM
We'd need to process an order to modify the connection to 21CN for you after the exchange upgrade.
We do those automatically in bulk but feel free to post when you know the exchange has been upgraded and we won't mind manually placing an order for you. FYI it should only take 24 working hours to complete too.
Adam
Adam
Message 2 of 4
(482 Views)
04-04-2013 11:35 AM
Hi Adam
That's great, thanks for your speedy reply!
Cheers
Andrew
Cheers
Andrew
Message 3 of 4
(482 Views)
04-04-2013 11:45 AM
Message 4 of 4
(482 Views)
