Ethernet Cables
TimBavard
Ethernet Cables
Hi, I have a Plusnet router and work from a MacBook Pro. My questions are:
(1) I no longer have the cables that came with my Plusnet router (which is less than a year old). So is there a specific type of ethernet cable I need to order, as when I searched on Amazon, the cables were HDMI, but my router doesn't have an HDMI slot?
(2) once I have the right cable, is it simply a case of plugging the cable in to my Mac and router?
Many thanks,
Tim
Tags (2)
7 REPLIES 7
Fixes: 1,484
Re: Ethernet Cables
what year is your MacBook Pro? More recent models don't have ethernet ports and you'll need an adapter.
as for cables just searching ethernet cable should be enough https://www.amazon.co.uk/s?k=ethernet+cable&crid=26ZMC5ZWVOVYO&sprefix=ethernet+%2Caps%2C322&ref=nb_...
Legend
Fixes: 255
Re: Ethernet Cables
Welcome to the forums @TimBavard Try searching for 'ethernet cable' on Amazon - I have just done so, and it brought up ethernet, not HDMI cables.
Once you have the cable, yes, just plug in and go.
One question - why can you not use wireless, as I assume you currently are?
EDIT: @dvorak makes a good point re: Macs and ethernet connections - I had forgotten, as I don't use one.
TimBavard
Re: Ethernet Cables
Cheers Dvorak, my Mac is around 3 years old, but I have a multi-port adaptor already, which has both an HDMI slot, 3 USB ports, and what looks like a phone-socket slot - which I guess would be for an ethernet cable?
Tim
TimBavard
Re: Ethernet Cables
Hi John, many thanks for your reply, I'll do as you suggest.
My understanding is that an ethernet conn section will give me a more stable connection than using the wifi - would that be right?
Tim
Fixes: 1,484
Re: Ethernet Cables
yeah the square socket that looks a bit phone is will be the ethernet port.
It should certainly provide a more stable connection than wifi.
Legend
Fixes: 255
Re: Ethernet Cables
Tim - how good is your current connection?
It is true that a cable connection is preferable to a wireless one, though.
TimBavard
Re: Ethernet Cables
It's not bad. Intermittent in the morning and on some evenings, but that would be down to traffic I suspect. However I need something more stable to broadcast my show which I've moved online, so trying an ethernet cable seems a good thing to do.
Cheers for all the help.
Tim Bavard
Bavard Bar
