Emergency dial-up numbers
- Re: Emergency dial-up numbers
11-01-2014 9:51 PM
In the Member Centre in Connection Details, above the box with all the information it states "We provide dial-up numbers for broadband accounts for emergency use. You can connect to these using a dial-up modem if you need to access the Internet from a different location, or if your broadband service is not working" In the box it says N/A. If dialup is ever required (I have a dialup modem) I'd need the number, should the ADSL fail. Is the dial-up number known or is it only available on request should the need arise?
Message 1 of 4
(1,138 Views)
3 REPLIES 3
11-01-2014 10:07 PM
It's N/A, as they do not offer it anymore. just another page that PN need to update.
Kind Regards
Mike
Kind Regards
Mike
Message 2 of 4
(654 Views)
11-01-2014 10:17 PM
Oh, right! Just as well I just remembered I have a Freeola dial-up account!
Message 3 of 4
(654 Views)
12-01-2014 4:04 AM
I was given access to an 0800 dialup account when I was stuck without ADSL for 6 weeks after a house move. If it's a long term problem with no ADSL at all and you make enough noise (and it's still available) you may be given the same.
Message 4 of 4
(654 Views)
