Emails are being lost (yet) again
- Emails are being lost (yet) again
21-11-2007 11:54 PM
Looking at previous emails from the same source I have one from the same person on 19th November and another from a different person in the same organisation on 20th - both of which came through critical path boxes. I've lost emails from before those emails successfully arrived.
What is going on?
Re: Emails are being lost (yet) again
22-11-2007 12:18 AM
Quote Thank you for your support query, in order for us to investigate this matter further,
Please advise us the date sent
the time sent and the destination mailbox
I'd given them the full headers from the the Google copy which has all the information he'd asked for - what a plonker!
22-11-2007 9:37 AM
Quite surprised as the CS analyst that replied to your ticket is normally very good. He's passed your ticket through to Networks though, who will be able to investigate your issue.
22-11-2007 9:57 AM
2007-11-21 21:05:45 your@email.address R=mysql_spamcore
T=local_spamfilter defer (145): Connection timed out:
error while writing to tmp/1195678845.H771673P16272.pih-sunmxcore12.plus.net
Basically it looks like one of the spam processes (Clam) is struggling to write information to a temporary file location. In layman's terms, the email's 'stuck' in one of the spam filters. I don't suspect this is going to be widespread but will have somebody look into into it none-the-less.
22-11-2007 11:33 AM
I've had a response to my ticket:
Quote I have had a look into this for you and it appears the mail in question is in the "Filed" folder of you mailbox (xxx). You should be able to find this mail by using the "search" option in webmail and entering "xxx@yyy" as you're[sic] search criteria.
If I could get on to the portal I would add the following response to the ticket:
The email you have found is the Google copy which I copied across using IMAP - if you look at the headers you will see that it doesn't have the normal Plusnet "Envelope-to: " at the top. In fact it has "Delivered-To: xxx@gmail.com" - that might have been a clue!
Edit: Finally managed to get on to the portal myself
22-11-2007 11:47 AM
If I turned off spam filtering - would it come out of the loop?
22-11-2007 1:34 PM
Good news is that we're due to be rolling an updated build out shortly. We've tested with this and it does seem to resolve the issue. Unfortunately, until this upgrade takes place there's no means of us pushing the email out. I don't think switching off spam or virus filtering would make any difference.
Oh, and to answer your first question, yes we can see other emails.
23-11-2007 11:47 AM
What's the betting that it's stuck in the same loop!
