Email not working
- Email not working
- « Previous
- Next »
Re: Email not working
12-06-2009 1:35 PM
Quote from: Gel Yes I find I can't send this morning except through my Yahoo port
ie
The message could not be sent because one of the recipients was rejected by the server. The rejected e-mail address was <name removed><at>awebb.org.uk'. Subject 'AWEBB new member notification', Account: '1 Tel', Server: 'relay.plus.net', Protocol: SMTP, Server Response: '550 relay not permitted', Port: 25, Secure(SSL): No, Server Error: 550, Error Number: 0x800CCC79
[Moderator's note by Jim (Oldjim) full email redacted ]
Is it just that recipient that you are having trouble with or all emails?
Message 61 of 64
(248 Views)
12-06-2009 1:40 PM
Quote from: tonycollinet
Quote from: gm4jjj Tony what mail client are you using?
Thunderbird/Imap
Last night I unchecked the "use authentication" (or whatever it is called - no password anyway), and it goes OK.
Will try again tonight with authentication enabled.
I can't replicate your problem Tony, your account seems fine to me.
220 relay.plus.net ESMTP Exim Fri, 12 Jun 2009 13:32:29 +0100
ehlo relay
250-ptb-relay02.plus.net Hello relay [84.93.217.165]
250-SIZE 104857600
250-PIPELINING
250-AUTH PLAIN LOGIN
250 HELP
auth login
334 VXNlcm5hbWU6
334 UGFzc3dvcmQ6
235 Authentication succeeded
Quote from: Username Now getting time out errors when accessing my pop3 boxes
Is this still happening? I've checked your default mailbox and it seems OK:
Trying 212.159.9.81...
Connected to mail.plus.net.
Escape character is '^]'.
+OK Hello there.
user *********
+OK Password required.
pass ********
+OK logged in.
ie
Are you sure you have SMTP authentication enabled? That looks to me like you're trying to send unauthenticated mail whilst not connected to our network?
Edit: @Gel, I've just tested SMTP auth on your account and it works fine.
Message 62 of 64
(248 Views)
12-06-2009 2:01 PM
Still can't receive my messages!
They show on webmail, but Outlook just times out! Only appear to have this problem on my main email account, username+popboxname look like they are OK....
Message 63 of 64
(248 Views)
12-06-2009 2:12 PM
Hiya - Have you tried removing and recreating that email account in Outlook?
Message 64 of 64
(248 Views)
- « Previous
- Next »
