Email not working
Username
Re: Email not working
Now I can't send anything via relay.plus.net (with authentication & connected via PlusNet) - Nothing's changed at this end since eariler today when it was all OK
bobpullen
Fixes: 316
Quote from: Username
About to get a Service Status out and a P1 has been raised.
Edit: SMTP auth problems should now be fixed. Our engineers found a truncated file that they believe was the cause of the problems.
tonycollinet
Well it is now 19:20, and I am still getting authentication problems. It has just refused to send a mail.
PS - I am using IMAP
gm4jjj
Tony what mail client are you using?
The_10th
Still can't send in either Thunderbird or Outlook via IMAP for me. Thunderbird password nags and Outlook reports an error code.
Username
Sorry to report it's still broken for me - I did manage to get a message out earlier after hitting retry numerious times...
jelv
Fixes: 10
It's still as the initial service status post for me. With authentication on it fails (although that was working earlier today) with authentication off it works.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
James
Thanks Tony.
We've just called out NEtworks and I've just updated Service Status.
jelv
Fixes: 10
It seems to be OK again now - a test finally worked shortly before 10pm.
Edit: I wonder if it is just individual mail servers that are affected - maybe some of them did not pick up the corrected file.
The_10th
Not working still and thus the fat lady hasn't sung.
jelv
Fixes: 10
http://usertools.plus.net/status/archive/1244791633.htm
Username
Now getting time out errors when accessing my pop3 boxes  Cry
Gel
Aspiring Champion
Fixes: 29
Yes I find I can't send this morning except through my Yahoo port
ie
The message could not be sent because one of the recipients was rejected by the server. The rejected e-mail address was <name removed><at>awebb.org.uk'. Subject 'AWEBB new member notification', Account: '1 Tel', Server: 'relay.plus.net', Protocol: SMTP, Server Response: '550 relay not permitted', Port: 25, Secure(SSL): No, Server Error: 550, Error Number: 0x800CCC79
jim:green full email redacted mod:end
Gel
Aspiring Champion
Fixes: 29
Angry Still not working; come on Plus Net this is main reason  I buy your service  Cry
No service status since 08.27am?
tonycollinet
Quote from: gm4jjj
Thunderbird/Imap
Last night I unchecked the "use authentication" (or whatever it is called - no password anyway), and it goes OK.
Will try again tonight with authentication enabled.
