Early Connection
- Re: Early Connection
Early Connection
30-03-2011 1:22 PM
hi i'v just had new phone line and i'm waiting for my broadband to be connected its due on 4th of april but my dsl light on router is green and im connected to the exchange at 8128 and 448 so alls good there just wont let me connect yet...so any chance of it earlier than the 4th preferably with interleaving switched off thanks
Message 1 of 7
(842 Views)
6 REPLIES 6
30-03-2011 1:36 PM
Hi katy1950,
can possibly get it on but can't change any settings. As the order is not complete with our suppliers then we cannot raise any faults/orders against it. If I manually activate it I cannot guarantee that it will work (although it normally does) and this will also start your billing process whether or not you can connect. Are you happy for me to go ahead with that?
Jojo
Jojo
Message 2 of 7
(530 Views)
30-03-2011 1:40 PM
Yes thanks that would be great
Message 3 of 7
(530 Views)
30-03-2011 2:18 PM
Ok, just make sure you have your details correctly set in your router.
Jojo
Jojo
Message 4 of 7
(530 Views)
30-03-2011 2:22 PM
Should be all good now
Message 5 of 7
(530 Views)
30-03-2011 2:26 PM
thanks a lot jo its working,,,much appreciated
Message 6 of 7
(530 Views)
30-03-2011 2:42 PM
Aw fab,
Welcome to Plusnet
Welcome to Plusnet
Message 7 of 7
(530 Views)
