ERROR: The account has no invoice in Failed Billing
ricky00130
Most sites work fine but there is a few that shows this error
image of how it looks like https://gyazo.com/1377ead7796de030ff01a17f6975c29e
This is one of the sites that shows this problem
http://store.nintendo.co.uk/amiibo/the-legend-of-zelda-collection.list?widget_id=131648
I've never had so many problems with previous providers, 2 broadband problems within a year and now this. Fix your [-Censored-] plusnet.
Moderator's note by Mike (Mav): Avoidance of swear filter edited as per Forum rules.
5 REPLIES 5
Fixes: 1,600
Re: ERROR: The account has no invoice in Failed Billing
Sorry to hear you're having problems.
I've seen this a few times, the fix is usually to disable and re-enable your account. I've just done that for you now.
Can you let me know how you get on?
Thanks,
Anoush
ricky00130
I've restarted my browser and the problem still shows. Do I need to reboot my broadband?
Fixes: 1,600
Yeah, it's worth rebooting the router.
TerryBrown
re booting my router having no effect on this problem. It's now a big problem as 4 days in and 3 session with PS support and no change - seriously slowing down my ability to work from home. Browsing the forums shows this has been a problem with PS for many years. If PS cannot fix this then I'm moving to a more reliable provider - soon.
HarryB
Fixes: 256
Sorry to hear that, are you still experiencing problems with this today? Is it happening on any particular sites, or intermittently across any sites?
 Harry Beesley
