Dropped packets / brief lags while gaming
xandermd
Hi there
Im new to plusnet and im experiencing an annoying problem. When im gaming (dota2 and mmos) I get a 'skip' or rubber-banding it only lasts about 1-2 seconds but its extremely annoying specially during clashes where every second is crucial
also i dont know if this is related to the problem but whenever im watching a live stream the video skips as well even at low resolutions. Package is Unlimited Fibre 80/20. No clue if im on 21CNor 20CN
Are the dropped packets the culprit ? If so what can I or Plusnet do to fixed it ?
I tried 2 routers the PN router and my n66u both have similar problems in wired/wireless connections. Also it happens at random time of the day
Note: I didnt have this problem with my previous ADSL ISP and the only thing that has changed is the move to Plusnet
TBB Live Graph
<a title="Broadband Ping" href="http://www.thinkbroadband.com/ping/share/9087c9e96fd57a7bc237f96f09ff9da3.html"><img alt="My Broadband Ping - PlusNet 77400" src="http://www.thinkbroadband.com/ping/share-large/9087c9e96fd57a7bc237f96f09ff9da3.png" /></a>
Fixed Graph incase the live graph doesnt show any dropped packets
23 REPLIES 23
Kelly
Fixes: 9
Re: Dropped packets / brief lags while gaming
You're currently on a 78000 speed profile on our side.  What download speeds are you seeing?
Also, can you get a bt speed test done and let us know what your speed profile is from that?
http://www.speedtest.btwholesale.com/
Kelly Dorset
Ex-Broadband Service Manager
Chris
Legend
Fixes: 169
I've made a slight tweak on our side to your speed profile (I've set it to 77400 instead of 78000 to match the IP profile of your line). Can you log in to teh router and disconnect/reconnect to see if that helps the packet loss?
xandermd
@kelly
Is this what you need?
http://i.imgur.com/haczd4Y.jpg
@Chris
Thanks I did what you said and ill post again in a few hours to see if it helped
Kelly
Fixes: 9
Yeah, your pn profile was higher than your BT profile meaning our QoS could have been wrong.  Chris has dropped your profile to match now.
Kelly Dorset
xandermd
cheers hopefully thats it fixed will post again if the drops still exists
Joopzor
could this be the same problem i am having with Twitch.tv lagging in the evenings?Huh
I also play dota and find this rubber banding? In the evenings i find my internet gets caps at 55 Mbps as well
chrispurvey
Hi Joopzor,
I've checked your profile and everything is set correctly, are you currently connecting with a wired or wireless connection?
Joopzor
connected via homeplugs, will max during the day but in the evenings my connection hangs around 55Mbps and Twitch seems to have lag when watching, this happens from 6PM and gateway hopping does help!
adamwalker
Fixes: 221
Hi Joopzor,
Thanks for getting back to us, mind running the TBB monitor for us (results of one of these are in the first thread of this post) so we can see if that's reflected in any particular way when the issue happens?
Adam
 Adam Walker
xandermd
4-days later...
I just want to report that the in game lags during gameplay seems to be gone now
although im still seeing  dropped packets in my TBB live graph is this normal ?
Joopzor
I have set this up but i do not have a static IP address, will keep a eye on it and update with new IP when required
dnrobs
i've joined up about this specific problem,i don't think it's ping or download but the upload is the problem i get 20-35 kb/s at best 0.35 MB/s i dont think this is enough you need at least 0.75 because lets face it all online gaming is doing is sending information to the servers so you only need about 100kb/s download.
i would pay extra for decent upload or even finish my term 10 months early because as it stands i can't game properly even at off peak times.
just a tablet and couple of phones sending location will slow it down to nothing aswell,maybe switch everything of and ban all other users for 2hrs a night or something.
chrispurvey
Hi dnrobs,
Firstly welcome to our community forums.
I've checked over your connection and can see no obvious cause why you're seeing those results.
Are you connecting via a wired or wireless connection?
Joopzor
and the speed reduction begins
