Drop in through speed
- Drop in through speed
30-12-2007 8:58 PM
I have been synced now at 7616 for at least 4 months and my through speed on the plusnet site was showing 6500, I've just been on the plusnet site and my through speed has reduced to 6000. Can anyone explain this to me and if any plusnet staff on, can you check it out for me.
[Moderator's note by Barry Zubel (zubel): CAPS removed from title - please refrain from posting titles in caps as per the link:rules]
Message 1 of 3
(835 Views)
2 REPLIES 2
Re: Drop in through speed
30-12-2007 9:09 PM
For your profile to drop to 6000 means that your line sync speed must have dropped to somewhere between 6816 and 7391 sometime recently. Have you been on the BT speedtester to see what your BT IP profile is showing?
Regards .....
Regards .....
Message 2 of 3
(258 Views)
31-12-2007 11:10 AM
Yes just tried again to post results has you can see 7616.
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 6000 kbps
DSL connection rate: 448 kbps(UP-STREAM) 7616 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 5603 kbps
Message 3 of 3
(258 Views)
