Drop in speed
- Re: Drop in speed
Drop in speed
19-08-2013 6:52 PM
For no reason I know of, my download speed is topping out at 3Mbps. I used to get about 15Mbps.
Router stats are as follows:
ADSL Link Downstream Upstream
Connection Speed 17778 kbps 888 kbps
Line Attenuation 29.5 db 12.6 db
Noise Margin 3.3 db 14.2 db
Can anyone see anything amiss in my stats? I opened a support ticket already, just wanted the forum expert opinion
Thnks.
Thnks.
Message 1 of 4
(938 Views)
3 REPLIES 3
Re: Drop in speed
20-08-2013 12:52 AM
Your router stats look OK. Is Current line speed in the Member Centre down at 3Mbps (probably because of a recent low sync speed)?
David
Message 2 of 4
(353 Views)
Re: Drop in speed
20-08-2013 10:08 AM
Hi spraxyt, yes my current speed in the Member centre is shown as 3.6Mb
Message 3 of 4
(353 Views)
Re: Drop in speed
20-08-2013 2:39 PM
I've bumped your profile so you should now see the correct speeds.
Message 4 of 4
(353 Views)
