Drop in speed after upgrade
- Drop in speed after upgrade
- « Previous
- 1
- 2
- Next »
Re: Drop in speed after upgrade
05-01-2010 10:55 AM
05-01-2010 11:11 AM
05-01-2010 11:13 AM
05-01-2010 11:23 AM
In fact, as it's a 21CN line it's really not as easy as that just to request an SNR reset. I'll see what I can do.
05-01-2010 11:27 AM
05-01-2010 11:29 AM
Thanks for all the prompt replies, much appreciated!
05-01-2010 12:12 PM
06-01-2010 11:38 AM
Was interested to know what the next steps would be after these tests?
If its of any interest heres the first test results
Test1 comprises of Best Effort Test: -provides background information.
Download Speed
2883 Kbps
0 Kbps 7150 Kbps
Max Achievable Speed
Download speedachieved during the test was - 2883 Kbps
For your connection, the acceptable range of speedsis 600-7150 Kbps.
Additional Information:
Your DSL Connection Rate :4539 Kbps(DOWN-STREAM), 440 Kbps(UP-STREAM)
IP Profile for your line is - 3000 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 14.43:25.63:59.94 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
If you wish to discuss these results please contact your ISP.
If you are experiencing problems with specific applications, servers or websites please contact your ISP for assistance.
Your test has completed please close this window to exit the performance tester.
Please visit FAQ section if you are unable To understand the test results.
06-01-2010 7:00 PM
Graham
06-01-2010 7:09 PM
Way outtta my league on this one
08-01-2010 10:02 AM
Does anyone know what this actioning would be/ If it will fix my speeds?
11-01-2010 8:13 PM
- « Previous
- 1
- 2
- Next »
