Drop In Profile
- Drop In Profile
Drop In Profile
12-10-2011 7:12 PM
Since Getting FTTC according to my router I've been connected for 20 days, but i've just noticed that my profile has dropped from 38Mb to 35Mb... Could anybody from Plusnet check to see if any disconnection caused my profile to drop.
Thanks.
Thanks.
Message 1 of 4
(806 Views)
3 REPLIES 3
Re: Drop In Profile
13-10-2011 11:28 AM
There was one disconnection mid-morning on Tuesday (11th) but I didn't think a single disconnection would be enough to reduce the sync rate/profile 😕
Message 2 of 4
(403 Views)
Re: Drop In Profile
13-10-2011 1:44 PM
According to BT Speedtester my line profile is 38Mb, but according to the connection section of your member centre my profile is 35Mb.... Is this normal or can you change your profile to match BT's.... I'm only a 30 second walk from the cabinet so should get full speed.
dick:quote
dick:quote
Message 3 of 4
(403 Views)
Re: Drop In Profile
13-10-2011 4:09 PM
Hi michellereid,
According to the BT system we use it says the profile is 35Mbps.
Jojo
Jojo
Message 4 of 4
(403 Views)
