Draytek Vigor 2760 Router not connecting
- Re: Draytek Vigor 2760 Router not connecting
31-08-2014 4:02 PM
We have just connected a Draytek 2760n router to the VDSL service.
Although I can see the connection via the dashboard screen. It won't connect! I have checked the username and password and they are correct. Does anyone know of other settings that need setting up?
Message 1 of 3
(1,760 Views)
2 REPLIES 2
31-08-2014 4:47 PM
Have you set the VLAN ID to 101 see here https://community.bt.com/t5/BT-Infinity-Speed-Connection/Replacing-openreach-modem-with-Draytek-2760...
Message 2 of 3
(1,327 Views)
31-08-2014 10:29 PM
Thanks for that. It worked a treat
Connected in about 45 seconds.
Cheers
Cheers
Message 3 of 3
(1,327 Views)
