Draytek IPsec VPN, anyone have any experience?
- Draytek IPsec VPN, anyone have any experience?
16-11-2010 4:34 PM
I have two LANs bridged via IPsec. I originally used Billion routers but between the 7500GL firmware not supporting SP3 and the 7402G's squirrely wireless I've gone off Billion these days.
Anyway I thought I had things working but I've had some extremely odd windows networking issues and I wondered if anyone else was running the same configuration (2 subnets bridged)?
Re: Draytek IPsec VPN, anyone have any experience?
16-11-2010 5:33 PM
16-11-2010 6:21 PM
I don't know what should happen with netbios and subnets? I'm not running WINS and I don't have a domain controller. I'm wondering if renaming the home "workgroup" might help. There never used to be any cross-over apart from using the IP.
16-11-2010 6:32 PM
Not quite sure what you mean here
Quote There never used to be any cross-over apart from using the IP
16-11-2010 7:49 PM
Quote from: MisterW TBH I've never had a lot of success using Netbios over VPN's. In my case, fortunately I don't need to as the remote machines are always accessed via IP directly.
I always took it for granted I'd have to access by IP, or set HOSTS file lines for the remote system. Thats how it used to be.
Today my home system's name appeared on the work network, and recently the home network has been unbrowsable. Its like the netbios records have somehow merged and all ended up on the work side.
16-11-2010 8:12 PM
Quote I always took it for granted I'd have to access by IP, or set HOSTS file lines for the remote system. Thats how it used to be.
Ah!, I suspect that the Billion setup maybe didn't support NetBios by default, I've just checked my 2820 VPN setup and it seems to have Netbios pass-though on by default ( at least I didn't put it on deliberately! ). Maybe that's why its different now. If you've not got a Domain Controller or a WINS server then I'm not sure what will happen with determining the Master browser when Netbios is broadcast across the VPN.
16-11-2010 8:53 PM
Currently I'm trying changing the workgroup name so any name leakage will be obvious, apart from that I can't find any way to control netbios behavior on the 2800 unless I can use firewall options, or something in the CLI.
17-11-2010 8:34 AM
Quote Also I can't find any way to determine which machine is browse-master, it all seems hidden.
It is, the master browser is automatically negotiated by the Windows browser.
On my 2820 there is an option 'Netbios Naming packet' on the Lan->Lan VPN settings ( see attached )
17-11-2010 9:20 AM
Only change I have noticed is I think on the Billion setup I had left RIP disabled, on the Drayteks I left it enabled. I wonder if this affects whether broadcasts are forwarded, if so that might account for the difference.
