Downstream SNR varying wildly
- Downstream SNR varying wildly
Re: Downstream SNR varying wildly
08-02-2016 5:01 PM
09-02-2016 9:22 AM
I'll upload some graphs, of before and after, then probably close this thread (well stop posting).
I'll leave the router monitor running, probably backed off to 10s, to see in the REIN returns.
09-02-2016 11:51 AM
<img src="http://community.plus.net/visualradius/generated/image14550185634563.png"/>
09-02-2016 2:58 PM
And this was with 1s recording, where I'd see any disconnect, as it takes more than 1s to reconnect. I show the reconnect at 3pm. Both graphs are DS noise margin btw
09-02-2016 8:47 PM
09-02-2016 9:00 PM
09-02-2016 10:54 PM
So the Radius log showed a disconnect and rapid reconnect between 10pm and 11pm - and so thats what my graph shows.
ejs has a good point, that yes I havn't thought about. ADSL sets up a uart (of kinds) that establishes a serial connection across multiple frequencies. Now I guess much of the frequency split, and multiplex, I would guess would be done in a specific hardware implimentation, leaving a uart exposed to the router OS. Router OS then takes the serial connection, and builds a ppp connection on top. So taking down the ppp conection is interesting - that would take an explecit ppp instruction, probably lcp - as between the ppp connection on each end is the hardware doing the frequency split and uart.
Hmmm - must be in logs, lets look:
1 2016-02-08 22:47:15 PPP Warning ppp0 LCP down
2 2016-02-08 22:47:15 PPP Error ppp0 LCP down
3 2016-02-08 22:46:51 PPP Error ppp0
4 2016-02-08 22:46:51 PPP Error ppp0 User request
5 2016-02-08 22:46:43 PPP Warning ppp0 LCP down
6 2016-02-08 22:46:43 PPP Error ppp0 LCP down
Bingo, ejs - yes ppp was taken down. Hmmm wonder now if I can switch on LCP debugging and see what command was sent. Alas thats setting ppp into debug mode. Simple config file, but will take a hack of the router ...
FInd below the noise margin for the relevent time. Indeed no drop of the ADSL connection. How intersting.
Other intersting thing, is even though recording the modem parameters every second, it shows the modem only updates it figures every 2s ...
10-02-2016 11:55 AM
Actually maybe I'm just wondering too much at the moment, broadband is up more stably that it has been for the last two years, so I shouldn't complain ...
10-02-2016 6:33 PM
An xDSL Status check by someone from CRT may give us a clue. Also have a look at your xDSL error stats.
10-02-2016 7:02 PM
Quote Downstream Link Info
Loop Loss: 45.3
SNR Margin: 6.6
Errored Seconds: 1
Hec Errors: N/A
Cell Count: 189740
Speed: 8053
On a side note, the upload is capped at 440. I'll get an order placed to get that uncapped while I'm on it. That should be complete by tomorrow
10-02-2016 9:50 PM
Errors - well not recoreded. But currently http says 0 pkts error - which I take to mean none that weren't corrected, how many corrected - well not avaiable on http. It may be avaible via telnet - but I'll need to take down current logging (as it locks the single telnet connection), and rewrite the logging code. Won't get time for that till sunday.
So we just have Harrys numbers.
Find attached the downstream noise margin for today. You can see the reconnect at 10am. Before 10am, it had previously synced at 6dB, so is down 2dB since then. After reataching it initially connected at 9dB, but quickly climbed until 9.5dB, until night fall.
Oh yes, had another ppp disconnect at 19:35, when adsl stayed up.
11-02-2016 10:17 AM
Whats not enoucharging though, had another drop of line. It dropped out at 1:45am this morning. Line looked stable before the drop - no signs of noise, and good noise margin (6.6dB). So seems clear that something is causing the line to drop, but alas there is no indication of what in the current logs.
[Edit: Strike that, found the cause of the 1:45drop - it was the resyncing of the upsteram from 444 to 888, so it makes sense as a remote resync.]
[reEdit: Oh just noticed a nice side effect of the upsteam sync being at 888 vs 444; my ping time has gone down from 60ms to 40ms! This is just to the first machine outsite (gateway in ptn)]
So looks like I'll have to switch on more logging on the TP-Link. Alas quick google on info thats avaiable on the telnet cli, and TP-Link doesn't sound good for error logs. So its sounding more like I'll need to hack the router, at least its openwrt inside - which I have experience with, so should be able to switch on more logs (well hopefully find a way of rejigging the lantiq firmware for the ADSL for more diagnostic info)
11-02-2016 2:13 PM
14-02-2016 9:55 AM
Have no idea whats causing it, looks like during the training period, that the exchange isn't happy with my line. But connection looks fine on myside. Now during training, I've disconnected twice myself (24 hours appart) to put in ejs changes to acess full telnet on the router. Other than that on my side its been up all the time, but I can see there have been a few ppp dropped sessions.
Anyway I'll look at enablng more logging on the tp-link, its a bit of a hassle, as the root file system is read only, so its not really viable to make configuration changes.
On yes, on the attached graphs also plotted upsteam margin, you can see something odd on the disconnect. Speed stayed at 888bps before and after - but the upsteam power changed. Not sure I'm reading the logs correctly, but looks like it chnaged from 12.4 dBm to 8.1dBm. Now granted that isn't a problem, as I have plenty of noise margin for 888bps - but anyone know whats going on there.
Anyway I'll keep adding logging details. So I can see what if anything is behind the resyncs.
14-02-2016 10:38 AM
If your router(s) are not supported try buying, of finding on freecycle, a hg612 (opernreach FTTC modem) these can be unlocked and provide lots of stats
Have a browse on kitz.co.uk about the DLM process http://www.kitz.co.uk/adsl/DLM_system.htm
I think DLM does not like error seconds and severe error seconds so these need to be monitored.
Ian
