Downloading slower than connection speed?
Fixes: 918
Re: Downloading slower than connection speed?
I'm glad to see that. I've adjusted the speed profile on your account now. If you do a single disconnect/reconnect of the PPP session in your router interface you should feel a bit of a boost in speed.
Thank you Gandalf, that seems to have done the trick. D/L 4.88Mbps. I tried to add a picture from http://www.speedtest.net/ but it doesn't display...
Can I expect that to be permanent, or is it possible it could resort to a lower speed.
Thanks again also to Townman for your help.
Fixes: 44
It is very much as I sought to hint at - given the reason why the DLM had 'managed' the line to such a high SNRM was not known / known to be resolved, it is possible that the DLM could do the same again.
Keep a watching eye on the SNRM and actual sync speed figures.
Thank you Townman.
