Download speed query!!!
- Download speed query!!!
07-07-2019 10:09 PM
Re: Download speed query!!!
08-07-2019 5:53 AM
08-07-2019 9:00 AM
It also looks like you may have used the Chrome browser. I don't know if it's been fixed yet but the BTw speedtester a bit back gave faulty results with some browsers. Microsoft Internet Explorer amd Edge were known to work.
Alternatively have you tried any other speedtester such as the Thinkbroadband one?
Your reported speed is worse than slow. If you put your phone number in here what speed does it say that you should be getting? https://my.btwholesale.com/includes/adsl/adsl.htm?s_cid=ws_furls_adslchecker
08-07-2019 11:07 AM - edited 08-07-2019 11:10 AM
Hi @Lel_sdw,
I'm sorry that you're experiencing poor speeds and for any inconvenience that this is causing you. I've tested your line and the test indicates that your line is currently syncing at 16.4mbps:
xDSL Status Check | |||
Circuit ID: | CBUKXXXXXXXX | Service ID: | BBEUXXXXXXXX |
Telephone NO.: | NA | Test Executed On: | 08-07-2019 11:01:26 |
xDSL Status Test Summary | |||||
Sync Status: | Circuit In Sync | ||||
General Information | |||||
NTE Status: | NTE Power Status: | Unknown | Bypass Status: |
Upstream DSL Link Information | Downstream DSL Link Information | |
Loop Loss: | 24.0 | 24.0 |
SNR Margin: | 5.8 | 6.1 |
Errored Seconds: | 0 | 0 |
HEC Errors: | 0 | |
Cell Count: | 8 | 26 |
Speed: | 899 | 16454 |
Maximum Stable Rate (KBPS): | 22688 | Fault Threshold Rate (KBPS): | 18150 | ||
Mean Time Between Retrains (Seconds): | 86400 | Mean Time Between Errors Upstream (Seconds): | 86400 | ||
Indicative Line Quality: | G | Mean Time Between Errors Downstream (Seconds): | 5082 | ||
Custom Thresholds | |||||
MTBR_RED: | MTBE_RED: | ||||
MTBR_GREEN: | MTBE_GREEN: |
However, there is a copper line fault that looks to be significantly impacting the performance on your side:
Copper Line Test | |||
Circuit ID: | CBUKXXXXXXXXX | Service ID: | BBEUXXXXXXXX |
Telephone NO.: | NA | Test Executed On: | 08-07-2019 11:04:01 |
Status: | Fail | MFL: | CA | OR Test ID: | cbs00556dat01:170028728 |
Test Outcome: | CIDT FAULT - HIGH RESISTANCE IMBALANCE DETECTED | DTR: | T311 |
Copper Test Details | |||
A to E | B to E | ||
Capacitance: | 75 NanoFarad | 75 NanoFarad | |
DP Line Length Estimate: | 1323 Metres | DN Line Length Estimate: | 1335 Metres |
Celerity: | 20 dB | Line Loss: | 17.87 dB |
Line Stability: | |||
Fault Report Advised: | Y | ||
Service Level: | 2 | ||
BRAGOutcome: | Good | ||
Faceplate: | Cannot Be Detected |
The test has been unable to determine whether the fault is internal or external to your property, so we'll need to do some troubleshooting to start ruling things out. I'd recommend starting with basic checks here: http://goo.gl/p2tpvL If these checks don't resolve the problem, the next step would be to connect your router directly to the test socket, which is under the faceplate of your master socket and seeing if the connection stabilises. This rules out internal wiring, face plates and extension sockets as being the cause. Please see the following guide for instructions on how to connect to the test socket. https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242
Please let us know if your speed is still poor when the router is connected to the master socket.
11-07-2019 8:18 PM
Lesley
12-07-2019 9:41 AM
@Lel_sdw, that's good news. Keep an eye on the connection and update us here if you have any further problems.
13-07-2019 11:28 AM
- Is it possible for me to run the xDSL Status Check and Copper Line Test? myself, or is that something only Plusnet Help team member like you can do?
Thanks again,
13-07-2019 3:12 PM
