Download speed had dropped
- Re: Download speed had dropped
22-04-2009 9:46 AM
I'd noticed that my Rapidshare downloads weren't reaching more that 400 kps this morning when I'd expect around 700. Ran a PN speed check which confirmed speed was slow. Peak usage at 1.08GB so no issues there. Before you ask I also performed a BT test. Any ideas why this is happening?
Results of BT Test:
Test1 comprises of Best Effort Test: -provides background information.
Your DSL connection rate: 7616 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 6500 kbps
Actual IP throughput achieved during the test was - 4829 kbps
Results of BT Test:
Message 1 of 6
(1,146 Views)
5 REPLIES 5
22-04-2009 11:24 AM
Any help out there? My speed is now varying from around 250 to 500 kbps mark. Something is definitely off though.
Message 2 of 6
(571 Views)
22-04-2009 12:11 PM
Please post the results of this speed check http://www.mybroadbandspeed.co.uk/ so we have some actual figures
Message 3 of 6
(571 Views)
22-04-2009 2:43 PM
Strange - whenever I've queried my speed in the past someone always asks for the BT speed test to be run as I'm told it's more accurate. The one time I pre-empt that request someone asks for the PN version
Anyway, my speed seems close to normal at the moment. I'll post back tomorrow if the problems reappear.
Message 4 of 6
(571 Views)
22-04-2009 4:38 PM
The BT speedtest has been a bit dodgy lately.
The reason for asking for the other test is that would pick up a problem at the Plusnet end as your BT test result wasn't too bad
Message 5 of 6
(571 Views)
22-04-2009 5:33 PM
They may have got it sorted -
http://community.plus.net/forum/index.php/topic,75560.msg606851.html#msg606851
I had quite a sensible result when I tried it this morning.
Message 6 of 6
(571 Views)
