Download fault
- Download fault
Re: Download fault
05-08-2010 2:32 PM
Quote from: Lorenzo48 Thanks, if you post me yours I'll try that as well. See post 1
Fine, just make sure you courier it back to me the same day.
I know you have tried several routers but it struck me that the symptoms seemed like a router problem. So maybe it is the closest equivalent, a problem with the line card in the telephone exchange?
Re: Download fault
05-08-2010 3:40 PM
For testing I used the D-Link 320 (i think) modem supplied by Plus 2 years ago and a new Draytek Vigor. The router that Died was a D-Link (420 I think) 2 years old. It bascially lost all power, this may have - as it died upset my connection?
It just occurred to me looking on kitz that they are building some new houses about half way between me and the exchange ...........
Re: Download fault
05-08-2010 4:19 PM
Re: Download fault
05-08-2010 4:48 PM
Let me go home later and double check everything and put another filter on as you've noticed disconnects still.
Got 2 brand new d-link filters so can go get one out the loft
Previous filters were a generic one and an ADSL Extreme (I think)
Do you need me to diasble any firewalls again?
I'll update the ticket tonight with a time relating to tonight.
Re: Download fault
05-08-2010 5:05 PM
Re: Download fault
05-08-2010 5:56 PM
Disconnected at 5:45 ish
In master socket - new filter - online 5:55 ish
Will leave it in place.
Re: Download fault
06-08-2010 9:45 AM
Re: Download fault
06-08-2010 2:50 PM
If I don't hear anything I'll drop you a line when I get back and will try and answer any tickets via blackberry but not sure if I'll have a signal.
Re: Download fault
06-08-2010 4:45 PM
Re: Download fault
15-08-2010 12:00 PM
Did some more digging and found out the new Dreytek has a firware issue where it MAY limit via QOS even when it is disabled like I have done.
TELNET'd in and set rx and tx to 100 and did an adsl reboot and it seems to have fixed it..............congrats to the above poster who suggested router problem.
Password: ********
Type ? for command help
> show adsl
--------------------------- ATU-R Info (hw: annex A, f/w: annex A) -----------
Running Mode : G.DMT State : SHOWTIME
DS Actual Rate : 5792000 bps US Actual Rate : 448000 bps
DS Attainable Rate : 5792000 bps US Attainable Rate : 1148000 bps
DS Path Mode : Fast US Path Mode : Fast
DS Interleave Depth : 1 US Interleave Depth : 1
NE Current Attenuation : 37 dB Cur SNR Margin : 14 dB
DS actual PSD : 19. 8 dB US actual PSD : 12. 0 dB
ADSL Firmware Version : 232201_A
-------------------------------- ATU-C Info ---------------------------------
Far Current Attenuation : 21 dB Far SNR Margin : 24 dB
CO ITU Version[0] : 00005000 CO ITU Version[1] : 00000000
DSLAM CHIPSET VENDOR : < CTLM >
> adsl stat
Read of issues with TI DSLAMs and vigor so ran this and seems to be not TI?
Anyway, to cut a long story short I am going to monitor for a few days rather arranging an engineer as the line tests were all good.
I don't understand why my Dlink modem gave similar issues to the Dreytek router though?
Questions:
1. Is my US being throttled?
2. Has interleaving been switched back on?
..................Does it really need to be this difficult to get a connection with off the shelf hardware?
Ben could you monitor the line for 24 hours for me? I am going to stream lots of vids and download some big files to see what happens.
Re: Download fault
15-08-2010 12:37 PM
Re: Download fault
15-08-2010 6:15 PM
£120 router that can't stay connected?
Thanks for your help so far Ben, will try and update you and the ticket with the resolution in case you get anymore draytek issues.
Still bugging me that the DSL Modem had a similar issue...........chances of a 2 brand new items having a fault?
Re: Download fault
16-08-2010 11:11 AM
If so it might be worth switching filters out, particularly if there's anything in the premises adding interference. Try unplugging items one at a time and see if things stabilise, if so whatever it is might need double filtering or a different filter on it?
Re: Download fault
16-08-2010 4:26 PM
I have a wirless fax/printer and one phone base unit.
Phone goes into printer then the printer goes into the filter............so I suppose two unit are passing via one filter although only one or the other can be in used at anytime.
Is that wrong and do I double filter by putting them together with the DSl into the one nearest the wall?
Re: Download fault
16-08-2010 5:55 PM
It's never ending....................
Will have to disconnect and re-fit the dreytek to send screenshots to dreytek uk as they don't believe me and said the firmware i have is not released yet Maybe I have a foreign market router with incompatible firmware? We shall see.
