Down Load Speed/upload Speed and in game ping problem
- Down Load Speed/upload Speed and in game ping prob...
- « Previous
- Next »
Re: Down Load Speed/upload Speed and in game ping problem
21-01-2014 11:11 AM
Uptime: 0 days, 9:46:52
DSL Type: ITU-T G.992.1
Bandwidth (Up/Down) [kbps/kbps]: 448 / 3,200
Data Transferred (Sent/Received) [MB/GB]: 808.58 / 15.13
Output Power (Up/Down) [dBm]: 12.1 / 18.0
Line Attenuation (Up/Down) [dB]: 31.0 / 49.0
SN Margin (Up/Down) [dB]: 19.0 / 9.8
Loss of Framing (Local/Remote): 9 / -
Loss of Signal (Local/Remote): 1 / -
Loss of Power (Local/Remote): 0 / -
Loss of Link (Remote): -
Error Seconds (Local/Remote): 327 / -
FEC Errors (Up/Down): 99 / 7,017
CRC Errors (Up/Down): 106 / 630
HEC Errors (Up/Down): - / 3,206
Can some one from DCT tell me if you done a SNR reset and/or turned interleaving off as my sync speed now is appalling compared to when it was first syncing when I join and even compared to O2 it's to low, also why have I had my upload speed capped again when I asked for it to be removed ?
21-01-2014 11:31 AM
Now is the time to leave it alone and see how it goes for the next few days.
Edit: Just noticed the upload seems to be capped when it was not on the previous stats. What is going on?
21-01-2014 2:25 PM
Uptime: 0 days, 13:10:20
Data Transferred (Sent/Received) [MB/GB]: 888.26 / 18.04
SN Margin (Up/Down) [dB]: 19.0 / 15.7
Error Seconds (Local/Remote): 329 / -
FEC Errors (Up/Down): 99 / 9,640
CRC Errors (Up/Down): 106 / 633
HEC Errors (Up/Down): - / 3,218
22-01-2014 11:08 AM
Uptime: 1 day, 9:50:42
Data Transferred (Sent/Received) [GB/GB]: 1.01 / 21.45
Error Seconds (Local/Remote): 364 / -
FEC Errors (Up/Down): 109 / 22,340
CRC Errors (Up/Down): 106 / 703
HEC Errors (Up/Down): - / 3,78
1. Why is my upload speed at 448 when I asked for uncapped?.
2. Is it worth doing a SNR reset so I can get my old speed sync back?.
3. Would it be better if interleaving is on or off ?.
4.Would it not be better if I was on ADSL2+ profile, so I could get similar sync to when I was on O2 ?.
5. or would it be better to ring support up, after last time they where next to no help?.
22-01-2014 4:13 PM
Uptime: 0 days, 0:07:16
Bandwidth (Up/Down) [kbps/kbps]: 448 / 4,480
Data Transferred (Sent/Received) [GB/GB]: 1.11 / 23.14
Output Power (Up/Down) [dBm]: 12.3 / 18.8
Line Attenuation (Up/Down) [dB]: 31.5 / 49.5
SN Margin (Up/Down) [dB]: 20.0 / 9.1
Loss of Framing (Local/Remote): 18 / -
Loss of Signal (Local/Remote): 2 / -
Error Seconds (Local/Remote): 385 / -
FEC Errors (Up/Down): 0 / 283
CRC Errors (Up/Down): 0 / 5
HEC Errors (Up/Down): - / 13
23-01-2014 2:55 PM
The upload was uncapped, but unfortunately a recent order to turn interleaving on also capped it. I've tweaked your account so that won't happen again and also placed another order to uncap, that'll complete tomorrow morning for you.
Hope that helps, and that the speed keeps up at a decent level for you.
24-01-2014 10:29 AM
After the exchange problems on wednesday and messing me up again, was told that an SNR reset was the only thing to do if it did not sort it self out, so just got of the phone and was told that the system that they use to do an SNR reset was down and is leaving it with the faults team, can you make sure that they do an SNR reset for me but leave my upload speed capped so I can see how the line goes please.
But thanks for your help Matt
28-01-2014 3:16 PM
Is the training period different with adsl max/2+ as in it lowers your SNR and increases your sync rate over the 10 days or am I wrong here ?
Stats after 12 hours up
Uptime: 0 days, 12:00:06
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 864 / 3,190
Data Transferred (Sent/Received) [MB/GB]: 122.14 / 2.71
Output Power (Up/Down) [dBm]: 12.6 / 0.0
Line Attenuation (Up/Down) [dB]: 32.7 / 52.5
SN Margin (Up/Down) [dB]: 8.5 / 9.4
Loss of Framing (Local/Remote): 9 / 0
Loss of Signal (Local/Remote): 1 / 0
Error Seconds (Local/Remote): 44 / 0
FEC Errors (Up/Down): 3,009 / 1,304
CRC Errors (Up/Down): 0 / 11
HEC Errors (Up/Down): 0 / 124
01-02-2014 11:08 AM
I just hope it can stay this high now and not mess up come evening time like last time on ADSL 1
Uptime: 0 days, 3:09:43
Bandwidth (Up/Down) [kbps/kbps]: 866 / 5,184
Data Transferred (Sent/Received) [MB/GB]: 915.29 / 19.67
Line Attenuation (Up/Down) [dB]: 32.7 / 53.5
SN Margin (Up/Down) [dB]: 6.1 / 3.3
Loss of Framing (Local/Remote): 27 / 0
Loss of Signal (Local/Remote): 3 / 0
Error Seconds (Local/Remote): 255 / 1
FEC Errors (Up/Down): 959 / 8,948
CRC Errors (Up/Down): 0 / 81
HEC Errors (Up/Down): 0 / 400
02-02-2014 2:31 PM
I can have a good sync during the day but from any time from 18:00 hours on it can start, my SNR will slowly go do way down like from 3.0 db to 1.0db or can go right down to 0 and show a lot of numbers but it is still connected in router, still have DSL stats but can't surf any website as it takes to long to load and then times out, can't even ping from cmd, in game it goes from being good to a lot of packetloss, like laggy and teleporting round the map. the only way to get back online is to restart the router which in turn syncs me lower.
Never had this sort of problem with O2 would stay rock stable 24/7
02-02-2014 7:12 PM
SNR started falling from 3.0db at about 17:15 when the street lights were coming on then for the next hour it fell to 2.0db it would then go up and down from 1.9 db-2.4 db.
Router stats during the problem, when it was still connected to the internet but could not load or ping anything
Uptime: 0 days, 2:31:35
Bandwidth (Up/Down) [kbps/kbps]: 864 / 5,238
Data Transferred (Sent/Received) [B/B]: 0 / 0
Line Attenuation (Up/Down) [dB]: 32.8 / 53.5
SN Margin (Up/Down) [dB]: 9.0 / 429496728.0
Error Seconds (Local/Remote): 1,426 / 0
FEC Errors (Up/Down): 108 / 110,771
CRC Errors (Up/Down): 0 / 82,463
HEC Errors (Up/Down): 0 / 171,117
Notice what my SNR is playing at
Hitting connect in the router at the time comes up with this message
Connection could not be established: Could not bring up link
When it did come back after a restart it took 2 tries at the connect button to connect back up, new stats after reboot
Uptime: 0 days, 0:14:55
Bandwidth (Up/Down) [kbps/kbps]: 864 / 4,025
Data Transferred (Sent/Received) [kB/kB]: 220.89 / 682.06
Line Attenuation (Up/Down) [dB]: 32.8 / 53.0
SN Margin (Up/Down) [dB]: 8.8 / 3.0
Error Seconds (Local/Remote): 63 / 0
FEC Errors (Up/Down): 6 / 790,017
CRC Errors (Up/Down): 0 / 71
HEC Errors (Up/Down): 0 / 71
Notice the SNR is what I had before at 3.0 db but look at my FEC errors the more you refreash the page the worse it gets.
And all this after we had 3 power cuts round here, I really do hope that some one can help as this is getting annoying now having to restart my router when I'm in the middle of doing some thing else and the fact that I can have a good sync during the day and good SNR but come eving time it starts to play up..
Update
New router stats below it seems my SNR has now come back up to 7.6 db and the FEC error rates have now stopped
Uptime: 0 days, 4:21:14
Data Transferred (Sent/Received) [MB/MB]: 19.70 / 248.96
SN Margin (Up/Down) [dB]: 8.8 / 7.5
Error Seconds (Local/Remote): 891 / 0
FEC Errors (Up/Down): 569 / 11,120,633
CRC Errors (Up/Down): 0 / 1,132
HEC Errors (Up/Down): 0 / 1,393
Could you please see this now has it would be easier to keep track of that this problem, sync is sorted now thanks to being on ADSL2+
http://community.plus.net/forum/index.php/topic,123291.0.html
- « Previous
- Next »
