Done fault check says everything is fine but it isn't
- Done fault check says everything is fine but it is...
- « Previous
- 1
- 2
- Next »
Re: Done fault check says everything is fine but it isn't
04-11-2014 11:44 AM
It is not uncommon for POTS tests and ADSL tests to disagree. Who provides your phone line?
There is a possibility that this is a router issue or an internal wiring issue.
You have not yet completed some if the basic end user checks - cancellation seems premature and unproductive. If the fault is within your premises or is an obscure line fault, then it will move with you.
04-11-2014 12:13 PM
04-11-2014 2:19 PM
Quote from: Dwivvc Thank you all for your help but unfortunately ive had to cancel the internet as I disconnected a whooping 10 times yesterday! "No fault was found on your line" I disagree!
Where did this "No fault was found on your line" come from? If it was the automated faults checker, you can ignore it as no exhaustive testing will have been done. You seem to have given up far to quickly, but if you are moving, it could depend on how long before you move.
Are you not going to have broadband when you move? If so, cancelling if you are in a contract period is not the wisest of moves.
04-11-2014 3:57 PM
And thankfully the place I'm moving to is about 400 yards from my local exchange and will have have fibre optic so that will be just heavenly and no correctly not contracted so all is well.
04-11-2014 5:21 PM
I am very sorry that you wish to leave, as I really do believe that we can fix this if you were to remain with us.
There are a couple of references (such as "No issue has been identified in BTW network") to be found scattered across your fault ticket, though I cannot find one with your exact wording that you quote. This information is quite correct though, no BTwholesale fault has been found. This is quite normal and nothing to worry about though. It doesn't actually confirm that there isn't a fault. BTw, in this case have recognised the drops and asked us to double check everything at your side to ensure all your internal wiring checks have been done. Assuming they have been done, and the advice provided by members of the forum has been followed we can quite easily move to the next stage of investigation and I could probably (I'd need to double check this) have an engineer with you by Thursday or Friday.
Tony
04-11-2014 7:59 PM
05-11-2014 11:12 AM
We always try to learn from our mistakes, and I am now going through the history of the account to see if mistakes were made, what was done well, what wasn't done so well etc.
Tony
- « Previous
- 1
- 2
- Next »
